Fargo Posted February 7, 2008 Share Posted February 7, 2008 Just found out after pumping brake fluid through my (about to be fitted) UK spec front calipers that an O Ring that fits between the two halves has been crushed (by my own fair hands), Rang Steve Manley and he has not got this part listed. So what i need is a washer (2mm thick square edged, 12.5 OD x 10.5 ID. and that is suitable for brake fluid. Or a UK front caliper in and condition as long as its got the washers. HEeeeeeeeeeeeeeeeeeelpppp Link to comment Share on other sites More sharing options...
Nic Posted February 7, 2008 Share Posted February 7, 2008 Paul, Toyota sell a complete overhaul kit for the calipers which will include the part you need. You should be able to pick one up from your local dealer if you need urgently, the part number are 04479-14130 Rear Brake Caliper Overhaul Kit 04479-14140 Front Brake Caliper Overhaul Kit If you have any trouble I can supply these for a good price, but would take a few week to order. Link to comment Share on other sites More sharing options...
colsoop Posted February 7, 2008 Share Posted February 7, 2008 Toyota sell a complete overhaul kit for the calipers which will include the part you need. You should be able to pick one up from your local dealer if you need urgently, the part number are 04479-14130 Rear Brake Caliper Overhaul Kit 04479-14140 Front Brake Caliper Overhaul Kit is that the same as the kit you sent me Nic, if so it doesn't have that part in it. Link to comment Share on other sites More sharing options...
Nic Posted February 7, 2008 Share Posted February 7, 2008 is that the same as the kit you sent me Nic, if so it doesn't have that part in it. Yes it will be Col, sorry I thought it would include that part also. Link to comment Share on other sites More sharing options...
colsoop Posted February 7, 2008 Share Posted February 7, 2008 Yes it will be Col, sorry I thought it would include all the seals. Nope sadly not. i don't think Toyota has the provision for the calipers being taken apart, i looked through the EPC and couldn't find any. Just a thought but would one of the injector o rings be the right size ? Link to comment Share on other sites More sharing options...
Nic Posted February 7, 2008 Share Posted February 7, 2008 Nope sadly not. i don't think Toyota has the provision for the calipers being taken apart, i looked through the EPC and couldn't find any. You're right, just checked the EPC and it doesn't list the part separately. Link to comment Share on other sites More sharing options...
Fargo Posted February 7, 2008 Author Share Posted February 7, 2008 yeh Mr Manley looked at the EPC, and its not listed, Colin, what are the dimensions of the injector rings, are they square edged (but i guess that not really a problem, a seal is a seal) and will they be suitable material. Link to comment Share on other sites More sharing options...
Robert Posted February 7, 2008 Share Posted February 7, 2008 yeh Mr Manley looked at the EPC, and its not listed, Colin, what are the dimensions of the injector rings, are they square edged (but i guess that not really a problem, a seal is a seal) and will they be suitable material. hi mate, there is a hose and fitting shop 2 mins from Phoenix, maybe they might have something? Link to comment Share on other sites More sharing options...
colsoop Posted February 7, 2008 Share Posted February 7, 2008 yeh Mr Manley looked at the EPC, and its not listed, Colin, what are the dimensions of the injector rings, are they square edged (but i guess that not really a problem, a seal is a seal) and will they be suitable material. I don't know bud. try asking one of the kind souls here if they could measure them: http://www.mkivsupra.net/vbb/showthread.php?t=139510 Link to comment Share on other sites More sharing options...
Fargo Posted February 7, 2008 Author Share Posted February 7, 2008 hi mate, there is a hose and fitting shop 2 mins from Phoenix, maybe they might have something? Where would that be Rob. @ Colin, Have just asked on the injector thread if they can help me out. Link to comment Share on other sites More sharing options...
Robert Posted February 7, 2008 Share Posted February 7, 2008 Its just past the station mate, walk toward the shopping center and you can't miss it, its about 2 mins from the station. Link to comment Share on other sites More sharing options...
