tbourner Posted January 19, 2005 Share Posted January 19, 2005 I've actually reversed the IDE cable round completely so that I could have a slighly longer ribbon between the two drives and in a lot of cases - the IDE bus doesn't like you doing this and will pi$$ you around when trying to detect both drives on the bus. I thought that was only with floppy drives, with the twisted/untwisted cable problems? Quote Link to comment Share on other sites More sharing options...
Duffers Posted January 19, 2005 Share Posted January 19, 2005 Oh, the dreaded floppy cable, yes! Maybe it's just Dell GX-110's that do that then - it really did pi$$ me around when the IDE cable was reversed. THEN, I noticed that one end of the IDE cable had the word "Controller" printed on it in tiny tiny tiny print. I swapped it back and it worked fine. I'm sure I've done this before on other systems and it's been fine but my Daughter's Dell was having none of it. I just thought it might be something to try... Paul Quote Link to comment Share on other sites More sharing options...
Grazer Posted January 21, 2005 Author Share Posted January 21, 2005 Tried swapping cables round - no change. The plot thickens!! Thanks for the CD Jake Installed XP on the 120GB drive as single/master (although BIOS still does not recognise it - when I try to auto detect it crashes). XP runs fine until I plug in a USB device when it freezes. This is a problem as my cable modem is USB (as well as everything else). I've had to put the other HD back in to get online - so help needed so I can stop swapping these drives round!! Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted January 21, 2005 Share Posted January 21, 2005 Well it's been a while since I used 98 but I'm pretty confident . . . . Your right they are, i got one at work. It may crash on auto detect if your motherboard doesnt support up to that size of hard disk. What motherboard is it? Quote Link to comment Share on other sites More sharing options...
Grazer Posted January 21, 2005 Author Share Posted January 21, 2005 Apparently it's a Saturn board (it's an NEC PC). I've got my BIOS ID but can't work out how to get a flash upgrade from that. Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted January 21, 2005 Share Posted January 21, 2005 ok what processor is it?? i was hopeing for model number of baord, but i may be able to use the processor to find out which particular board range it is. Quote Link to comment Share on other sites More sharing options...
Grazer Posted January 21, 2005 Author Share Posted January 21, 2005 Its an 800MHz PIII Quote Link to comment Share on other sites More sharing options...
