Need hard drive help!!
Grazer
My hard drive was full of crap and running badly so I backed everything up and formatted it - only prob is I then couldn't install Win98 back onto it.
I used the recovery disk that came with the PC but it said something like "sector not found on A:" and then wouldn't read the CD drive.
Anyway, I found an old 20GB drive that had an OS installed which I've put in and am using now.
Here's what I don't get:
I've attached both HDs with the 20GB one as master and the formatted 120GB drive as slave but when windows starts I don't see the other drive.
Should it just appear as another drive or am I missing something.
I need help as I can't fit much on a 20GB drive!!!
:stupid:
You should check for HD drives in the BIOS
Hmm - no matter which way I arrange the drives and jumpers it says:
Primary IDE Master: 20GB
Primary IDE Slave: Not detected
It even says this when the 20GB drive isn't plugged in!!!
Possibly wrong jumper setting for slave or cable wrong way round.
The 20GB drive doesn't have a picture on it like the 120GB drive - it says:
Jumper J50
Master/Single - On
Slave - Off
What does J50 mean!
:stupid:
Go into the bios and change the secondary drive to Auto detect.
The drive didn't show up in the bios. There was an option to auto-detect hard drives and every time I select it the computer crashes!
Thanks for the help guys - keep it coming :D
Does the PC see the 120gb drive if you set it as Master and connect it on its own (without the other HDD in the PC) and with bios set to Auto?
Yes.
But the problem is that I can't install my OS on it.
I've done this before, and I usually use the recovery boot disk in A: which prompts me to insert the Win98 CDs and installs it all. That's not working this time!
Yes.
If it's Win98SE the CD is bootable, so change the boot sequence in the BIOS to boot from the CD drive before the HDD or FDD. Then reboot the PC with the Win98SE cd in the drive and install the OS from there.
No, its not mate, honest :)
Win 98 has got no .bin files on the root of the disc. It autoruns from within Windows but you can't boot from it.
Anyway enough of the :hijack:
Grazer, if you can't make a boot floppy from Win98 PM me your email, and I'll send you a self extracting archive of a boot floppy utils disc.
You probably need to do a drive scan from BIOS, is it an old motherboard? (see bottom of post.)
Jumper J50
Master/Single - On
Slave - Off
What does J50 mean!
That means there is a jumper on the drive board somewhere with 'J50' written next to it or near it, you need to take the jumper plug OFF of it to set it to slave.
If it crashes when you auto detect then you'll need to format the drive again I'm guessing and if it doesn't work then it's a duff drive! Hopefully the J50 removal will get BIOS to see it.
You need a win 98 boot disk, boot from it and type 'fdisk'. From there you can delete all partitions of the disk, create a completely new partition (or more if you like) and format it as FAT32 (I think win98 boot disks do FAT 32 don't they?).
Ok - just looked at my CDs with win98 on them - "for Packard Bell computers only, will not function on other computer systems"
I forgot I bought a new PC recently - not a PB
:stupid:
Is there a way round this, or should I be thinking about splashing out for XP?
Hi Geoff
I think you're talking about Win98 and I'm on about Win98SE
My copy of Win 98 SE is definetly bootable. I don't think vanilla Win98 was though.
Grazer,
Email me you address if you want me to post you a copy of Win98se or Win XP
Hi Geoff
Grazer,
Hi Jake, I'm talking about Win98SE also
How can I put this ;) Is your copy of Win98 a real one or a backup? Or is it a branded copy supplied by Dell HP, PB or the like.
I know that manufacturers created bootable system restore discs and some people put boot files on "backup" copies but I'm sure the original (retail) ones didn't have them.
I could be wrong though, you never finish learning in this business :D
Win98 SE WILL boot from the CD, I'm certain of it as I've done it a number of times in the past. This is a fully licensed retail version I'm talking about, not an OEM special.
Cheers,
Brian.
Howdo mate...
Not sure if you got both drives working on the same cable but I've been guilty of this and its bitten me in the arse - I've actually reversed the IDE cable round completely so that I could have a slighly longer ribbon between the two drives and in a lot of cases - the IDE bus doesn't like you doing this and will pi$$ you around when trying to detect both drives on the bus. If you did unplug the IDE cable from the motherboard and plug the other end in to give you more cable then this is likely to cause it to fail.
There isn't much else to check really - I suppose you've tried another IDE cable and all that lark.
It's just a thought, as it had me ripping my hair out once a few years ago!
Good luck mate...
Paul
:upside:
