Paul Whiffin Posted February 6, 2008 Share Posted February 6, 2008 As above for pre-VVTi 6 speed manual only, £100 Link to comment Share on other sites More sharing options...
_Shane_ Posted February 6, 2008 Share Posted February 6, 2008 that is well cheap, i remember on a gt turbo forum i used to be on a few years back and any ecu like this whether its mines blitz toms etc was going for 500-600 sterling easily and they were all been sold Link to comment Share on other sites More sharing options...
spidermonkey Posted February 6, 2008 Share Posted February 6, 2008 As above for pre-VVTi 6 speed manual only, £100 what exactly does this do Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 6, 2008 Author Share Posted February 6, 2008 Basically, removed fuel cut, speed limiter and remapped ignition/fuel map, came off a car running 1.2 bar boost. Link to comment Share on other sites More sharing options...
spidermonkey Posted February 6, 2008 Share Posted February 6, 2008 Basically, removed fuel cut, speed limiter and remapped ignition/fuel map, came off a car running 1.2 bar boost. ah ok thanks for the quick answer:) Link to comment Share on other sites More sharing options...
steb9780 Posted February 6, 2008 Share Posted February 6, 2008 Nick got in touch with Mine's about mine and he found that it had various things like: top speed de-limited, fuel cut removed, mapped to 1 bar, rev limit raised to 8.5k IIRC Link to comment Share on other sites More sharing options...
steb9780 Posted February 6, 2008 Share Posted February 6, 2008 Oops to late. Link to comment Share on other sites More sharing options...
SupraShaun Posted February 6, 2008 Share Posted February 6, 2008 Does this run ok on UK fuel? Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 6, 2008 Author Share Posted February 6, 2008 There's quite a few people using in the UK so I would say yes. If I was fitting it I would check the afr's and det afterwards to make sure. Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 6, 2008 Author Share Posted February 6, 2008 Sold Link to comment Share on other sites More sharing options...
