1JZGTE Posted February 5, 2008 Share Posted February 5, 2008 Hello all I would like to know what a BPU will do for your fuel economy. By BPU, I mean: 1. Aftermarket exhaust system eg. Blitz NUR Spec 2. Electronic boost controller 3. Fuel cut defender 4. Cold air intake I appreciate that the Japanese had a gentleman's agreement with regards to bho output and so some of the cars were simply throttled, the Supra being an example. If driven like for like, what will I see in a car with BPU vs. without BPU with regards to MPG? Link to comment Share on other sites More sharing options...
Ric Posted February 5, 2008 Share Posted February 5, 2008 Nothing... Untill you put your foot down to get the extra horses you've released then it will obviously be lower. Link to comment Share on other sites More sharing options...
Pete Posted February 5, 2008 Share Posted February 5, 2008 No, it should raise it unless you're driving around at 70% + throttle all the time. Removal of the cats will help fuel efficiency. Link to comment Share on other sites More sharing options...
flukey-lukey Posted February 5, 2008 Share Posted February 5, 2008 ^^ lol... agreed Link to comment Share on other sites More sharing options...
1JZGTE Posted February 5, 2008 Author Share Posted February 5, 2008 No, it should raise it Really? I was under the impression that the parts I mentioned (oh and a cold air intake ) would shove more air in and more air = bigger bang with more petrol, thus reducing fuel economy? Am I completely wrong then? Link to comment Share on other sites More sharing options...
Daston Posted February 5, 2008 Share Posted February 5, 2008 Well in order for cats to work the engine has to burn more fuel to heat them up to the proper temp so really cats are worse to the enviroment for short trips Link to comment Share on other sites More sharing options...
R Black Posted February 5, 2008 Share Posted February 5, 2008 BPU'ing just makes the car breath easier, less stress on the engine so less petrol use, BUT as it breathes easier it will drink more if pushed. Link to comment Share on other sites More sharing options...
Pete Posted February 5, 2008 Share Posted February 5, 2008 Really? I was under the impression that the parts I mentioned (oh and a cold air intake ) would shove more air in and more air = bigger bang with more petrol, thus reducing fuel economy? Am I completely wrong then? I'm assuming you're removing the cats as per the BPU definition. Don't take my word for it, CW has said it many a time. Link to comment Share on other sites More sharing options...
1JZGTE Posted February 5, 2008 Author Share Posted February 5, 2008 Thnaks for the info guys. OK then, so am I right in thinking that the summary is this: BPU will make car breathe easier and thus for normal driving, MPG will largely be same or a little better. However, when pushed, the car will drink by the gallon? Link to comment Share on other sites More sharing options...
Pete Posted February 5, 2008 Share Posted February 5, 2008 Thnaks for the info guys. OK then, so am I right in thinking that the summary is this: BPU will make car breathe easier and thus for normal driving, MPG will largely be same or a little better. However, when pushed, the car will drink by the gallon? Well yes as you've raised the boost and the ECU will throw more fuel in, over fuel mainly at an AFR of under 10:1 You'll get some economy back (and extra performance) when you start tweaking the fueling with a decent ECU. Link to comment Share on other sites More sharing options...
