AndyT Posted August 9, 2008 Share Posted August 9, 2008 Lot of work there guys. Well done to you two. Link to comment Share on other sites More sharing options...
JamieP Posted August 9, 2008 Share Posted August 9, 2008 Have I missed something? What happened to the plans for a V8 lump? http://www.mkivsupra.net/vbb/showpost.php?p=1991893&postcount=325 Link to comment Share on other sites More sharing options...
Homer Posted August 9, 2008 Author Share Posted August 9, 2008 Cheers guys I'm really pleased this job is out of the way, it's a major step forward in the project. The only major things to do now is fit the diff, prop and one missing driveshaft. Once thats done it's just a case of hooking up the fuel system, PAS lines, the ECU/fusebox plugs, 2nd cat, exhaust and few other little things and it should be ready for a test fireup. If all goes well I'll give it a full service then it's off for an MOT and suspension reallignment. Link to comment Share on other sites More sharing options...
Homer Posted August 10, 2008 Author Share Posted August 10, 2008 Got the gearbox mount fitted today and one of the engine mounts secured (managed to lose one of the mount bolts, so need to buy another ) Also seem to have lost the bolt that secures the selector to the shaft, but have got the selector in, thankfully it all lined up correctly with the trans tunnel mod done last month (phew - and thanks to jezz for the advice earlier on this otherwise I'd probably have got it wrong!) The PAS cooler and lines are hooked up, seems they are interchangeable between the NA and TT which saved some hassle. The Air con lines are also connected up. Battery terminals are connected and one of the ECU plugs installed. I now have the oposite issue to the NA-TT conversion where the 2nd plug does not fit (TT fusebox, NA connector), so will asking some advice from the guys who've done the NA-TT conversion Most of the water and vacuum lines are conencted up and the air intake fitted but have an issue with one of the sensors (thread in tech!). The fuel filter bolt is frozen (the filter collapsed on itself when trying undo it!) so need to get another fuel filter, banjo and line to the rail. The aux belt is completely shot, so will order a new one tomorrow and fit that before connecting up the rad and installing the fan shroud. The engine was also tagged with a spray can while in the scrap yard (not sure why they do this), so started to clean that up, but it's going to take a while! Cam covers are removed and will get a repaint later in the week. Link to comment Share on other sites More sharing options...
Homer Posted August 13, 2008 Author Share Posted August 13, 2008 Bit short on time these days so only get about an hour to spend in the evening... Got the prop, diff and one of the driveshafts installed. Need to buy some 10mm and 12mm hex sockets to torque them up.. Also still need to find a driveshaft for the drivers side It looks like I'm missing the centre exhaust support bracket, does anyone know where it should be? Link to comment Share on other sites More sharing options...
JamieP Posted August 13, 2008 Share Posted August 13, 2008 Do you need a pair of seats mate? got a mint pair stock seats here you can have. Link to comment Share on other sites More sharing options...
Homer Posted August 13, 2008 Author Share Posted August 13, 2008 Do you need a pair of seats mate? got a mint pair stock seats here you can have. Thanks very much for the offer mate, very generous of you! but SteveR sorted me out with a mint set a few months ago Link to comment Share on other sites More sharing options...
JustGav Posted August 13, 2008 Share Posted August 13, 2008 Don't panic if you don't have an exhaust hanger, it may have been removed for some reason. I've got a mig welder and I'm sure my mate Phil can get a hanger from work. Link to comment Share on other sites More sharing options...
SteveR Posted August 13, 2008 Share Posted August 13, 2008 /me wonders if it will it be ready in time for Llandow/Supra Pod Link to comment Share on other sites More sharing options...
Homer Posted August 13, 2008 Author Share Posted August 13, 2008 Don't panic if you don't have an exhaust hanger, it may have been removed for some reason. I've got a mig welder and I'm sure my mate Phil can get a hanger from work. Nice one Gav. Think I might be a bit of a div here, but there are still the two stock hangers in place - left and right sides just infront of the diff, you can see the right one in the picture above. Is this where the aftermarket cat back exhausts normally connect (obviously on the left hand side) Edit - here's the pics of the exhaust and the hanger... /me wonders if it will it be ready in time for Llandow/Supra Pod Thats what I'm aiming for, but there is still a LOT to do so it'll be touch and go! Link to comment Share on other sites More sharing options...
bignum Posted August 13, 2008 Share Posted August 13, 2008 How many bits of other peoples car has gone into yours i wonder, i think everyone that has contributed should have a lap at Llandow, Link to comment Share on other sites More sharing options...
JustGav Posted August 13, 2008 Share Posted August 13, 2008 An NA race perhaps? But I won't be driving the NA, I'll let Mel drive Link to comment Share on other sites More sharing options...
SteveR Posted August 13, 2008 Share Posted August 13, 2008 How many bits of other peoples car has gone into yours i wonder, i think everyone that has contributed should have a lap at Llandow, They're MY seats, so if you want to sit on them... Link to comment Share on other sites More sharing options...
Homer Posted August 13, 2008 Author Share Posted August 13, 2008 How many bits of other peoples car has gone into yours i wonder, i think everyone that has contributed should have a lap at Llandow, *checks parts list* Yep, nothing donated from the 'num' brothers, so all should be okay An NA race perhaps? But I won't be driving the NA, I'll let Mel drive Erm, can I back out of that challenge quickly? Not sure I want to run the risk of getting beaten by a lady, I'd never live it down Link to comment Share on other sites More sharing options...
bignum Posted August 13, 2008 Share Posted August 13, 2008 *checks parts list* Yep, nothing donated from the 'num' brothers, so all should be okay Erm, can I back out of that challenge quickly? Not sure I want to run the risk of getting beaten by a lady, I'd never live it down lol,, you must need something. Link to comment Share on other sites More sharing options...
Homer Posted August 13, 2008 Author Share Posted August 13, 2008 lol,, you must need something. Drivers side driveshaft for an auto/NA diff Link to comment Share on other sites More sharing options...
SteveR Posted August 14, 2008 Share Posted August 14, 2008 Thats what I'm aiming for, but there is still a LOT to do so it'll be touch and go! Let me know if I can do anything to help. I'm good at making tea! Link to comment Share on other sites More sharing options...
Firestorm Posted August 14, 2008 Share Posted August 14, 2008 hey dude have you moved to gloucester yet.. maybe way off but if you have .. thats looks like you live in Longlevens? Link to comment Share on other sites More sharing options...
Homer Posted August 14, 2008 Author Share Posted August 14, 2008 hey dude have you moved to gloucester yet.. maybe way off but if you have .. thats looks like you live in Longlevens? Not yet mate, still here in Reading. The place I found in Longlevens fell through (my fault!) Link to comment Share on other sites More sharing options...
Firestorm Posted August 15, 2008 Share Posted August 15, 2008 ah rite okay mate, well let me know when you do- and if ya need any help- im sure im good at morale support! " Come on Homer..!!.. you own that nut!!" hehe see Link to comment Share on other sites More sharing options...
Homer Posted August 15, 2008 Author Share Posted August 15, 2008 Short update, no pics this time - Fuel ECU and pump loom rewired back to stock - Aftermarket fuel lines and filter removed - Exhaust and 2nd decat installed - Everything in the engine bay connected up (with a couple of exceptions, see below) - Shifter properly fitted Hopefully Jezz will be able to send the few remaining parts: - Drivers side driveshaft - Fuel tank donut - Fuel hose from filter to rail - 2x heater matrix pipes (managed to crush them fitting the engine ) - IAT sensor - Aux belt Then it's a case of doing the fluids (brake, PAS, Clutch and coolant) and it should be ready for starting Link to comment Share on other sites More sharing options...
SteveR Posted August 15, 2008 Share Posted August 15, 2008 ...Then it's a case of doing the fluids (brake, PAS, Clutch and coolant) and it should be ready for starting Insane Link to comment Share on other sites More sharing options...
Homer Posted August 16, 2008 Author Share Posted August 16, 2008 After a call with Jezz the fusebox loom issue was solved - only took a few minutes! Wires out of the NA plug: Fitted into the TT plug: Also fitted the newly painted engine cover and air intake duct, still need to clean up the rest of the paint off the engine, but thats not a priority. So, now thats the last thing hooked up, it was time to test the in-car electrics. Fitted an old battery that had been fully charged, fitted and and surprise - no fuses blew, no fire, nothing (well expect the horn stuck on all the time, which didn't half make me jump!). So, with the horn disconnected until I can figure out whats arong with it, started going through the interior.. What is working: - Heater controls and fans - odo and warning panel - right hand warning panel - right hand rear lights - indicators - Drivers headlamp - Electric wing mirrors - Windscreen wipers - dash lights What is not working: - Rear window demister - AC (known as it's got no gas in it) - left side rear lights, everything is lit up when the lights are on Then I realised the passenger headlamp was not plugged in, so did that, tried again and most stuff immediatly stopped working Tested the battery on and off the car and it's dropped to 7volts, so hopefully it's just that being duff thats caused it. So, now need to buy a new battery and start again with the testing. No fuses appear to have blown yet, which is a surprise! Thanks to Hadyn for the free rad cap Jezz is now supplying the rest of the parts needed (mentioned in the last update) which should hopefully arrive Tues/Weds, after which it should just be a case of installing them, putting some fuel and water in and firing it up The only thing I know thats missing it the upper rad/fan cover... Link to comment Share on other sites More sharing options...
JamieP Posted August 16, 2008 Share Posted August 16, 2008 Not long now, did you get to test the engine when it was in the other car? Link to comment Share on other sites More sharing options...
Homer Posted August 16, 2008 Author Share Posted August 16, 2008 Not long now, did you get to test the engine when it was in the other car? Unfortunately not! The guy in the scrap yard said it was a runner (driven in) so it *should* be okay Link to comment Share on other sites More sharing options...
