tDR Posted June 28, 2008 Share Posted June 28, 2008 Thanks for the info D that's good to know So the reason you have to do it is to locate the shifter in the right place? Does the Getrag box physically fit in the trans tunnel regardless? Link to comment Share on other sites More sharing options...
Homer Posted June 28, 2008 Author Share Posted June 28, 2008 Thanks for the info D that's good to know So the reason you have to do it is to locate the shifter in the right place? Does the Getrag box physically fit in the trans tunnel regardless? To your first question, yes. To the 2nd question, almost a cetain yes. The plate seems to be needed to accomodate the shifter mechanism rather that the box itself. Look at a full V160 and you'll see it for yourself Edit - that is unless you refer to the "rest" of the tunnel? They are the same on all supra's so any transmission can fit in there. The shifter mechansim is the issue as it sits on-top of the gearbox itself. Link to comment Share on other sites More sharing options...
Homer Posted July 27, 2008 Author Share Posted July 27, 2008 Very little real progress recently, still waiting for people to be available to help fit the engine My father was going to help this weekend but was called into hospital for a knee opp, which will put him out of action for 4 months. But in the mean time got a few little jobs done: - Rewired the headlights and indicator wiring (found these to be hacked - suprise, suprise!) - Fitted front indicators - Fitted battery terminal wiring & battery tray - Fitted charcoal canister - Final fitting of brake lines - Replaced the incorrect bolt holding the lower front arm on - Installed all lamp bulbs (it came with none) - Fitted front bumper with new bumper mounts - Nearly managed to remove 2nd fuel line... - Fully fitted the door cards - Fitted rear view mirror - Fitted drivers pillar trim (had to trim up one from a hardtop, can't get aero bits anywhere!) - Re-torqued all calipers and suspension ..and tons of other stuff I'm forgotten about There's something wrong with the suspension on the drivers side rear still. No matter what I do the wheel has a huge amount of negative toe. Either the upper or lower arm must be bent as all the other parts have been replaced. Also reburbed the headlights as they were in a terrible state, very yellow and misty. Amazing what a little (5 hours!) cleaning and painting can do. They were so bad I had to resort to sand paper to take the top layer off, if trying this yourself, I highly recommend getting 2500 or 3000 grit papare as it makes the job SO much easier and the finish pretty much flawless. Before: After: Also painted the dash. Was really pleased how this came out, the colour was a bit of a chance (just picked it off the shelf on Halfords), but it turned out just what I was aiming for. It's Ford Graphite Grey Metallic. I've left it without laquer so it doesn't go shiney (can't stand the reflections you get on some painted dashes) Only parts that I need to source now is a drivers side driveshaft (Hopefully Terminator is sorting this out) and the donut that holds the pump hanger in place Also a quick few thanks: - Scooter for providing a 3inch cat back for free! Thanks mate - Deano H for the nicely priced stock airbox and system - Lukeboy2k for sending the indicator wiring for free Total spend so far: £884.98 Link to comment Share on other sites More sharing options...
Trig Posted July 27, 2008 Share Posted July 27, 2008 Looking good Darryl Gotta say i really like the colour of the dash too Link to comment Share on other sites More sharing options...
Homer Posted July 27, 2008 Author Share Posted July 27, 2008 Looking good Darryl Gotta say i really like the colour of the dash too Thanks Trig, the photo really doesn't do it justice (crappy phone cam again!). It's a bit lighter in real life and there is a little more of a metallic look to it. Really must get a proper digi cam... Link to comment Share on other sites More sharing options...
Gazboy Posted July 27, 2008 Share Posted July 27, 2008 Darryl, my brothers first M3 had a chassis brace that seriously strengthened the car, it was also much more discreet than an ugly cage. Damned if I know who sells these as it came with the car when he bought it. Link to comment Share on other sites More sharing options...
MONKEYmark Posted July 28, 2008 Share Posted July 28, 2008 Edit - thats compressor stall, your new car will probably do it a fair bit. It sounds good, I never got tired of it thats an old video i took when i went to SCRaceway brings back memories good luck on the bulild Link to comment Share on other sites More sharing options...
Homer Posted August 2, 2008 Author Share Posted August 2, 2008 Got a few little jobs done today so everything is ready for the install next Saturday. First was to get the engine out of the trailer and give it a good going over. It all looks good, the oil and filter look like new so it looks like it's been cared for (will replace them anyway) One of the engine mounts is broken where the engine was dropped while being removed in the scrap yard (only about 1 foot, but had a soft landing on the front clip of the scrap supra - which near bent it in half!). Other than that, no damage, no apparent leaks, etc... Borrowed a hoist from a helpful neighbour! Engine now on an improvised 'stand' until next week Also started removing the door decals (which is proving to be a royal PITA to get some of them off...) Just need to get all the fluids and filters purcashed for the install (and hopefully) fire-up next weekend Link to comment Share on other sites More sharing options...
Ric Posted August 2, 2008 Share Posted August 2, 2008 you putting a NA lump in there? Link to comment Share on other sites More sharing options...
Homer Posted August 2, 2008 Author Share Posted August 2, 2008 you putting a NA lump in there? Yep, just for now. Reasons explained here: http://www.mkivsupra.net/vbb/showpost.php?p=1991893&postcount=325 Link to comment Share on other sites More sharing options...
JamieP Posted August 2, 2008 Share Posted August 2, 2008 Hair dryer is great for removing stickers;) not that you will have one:p Link to comment Share on other sites More sharing options...
Homer Posted August 2, 2008 Author Share Posted August 2, 2008 Hair dryer is great for removing stickers;) not that you will have one:p Lol, not used one for it's intended purpose since I was 18 Actually I bought one years ago to remove some stickers from the last supra, tried it again today and it helped with two of them, but the other are so old I'm scraping them off a few mm at a time and it's damaging the paint... Link to comment Share on other sites More sharing options...
tDR Posted August 2, 2008 Share Posted August 2, 2008 Dash looks great Darryl Petrol is best thing you can use to help get the stickers off / any left over adhesive Link to comment Share on other sites More sharing options...
Homer Posted August 2, 2008 Author Share Posted August 2, 2008 Dash looks great Darryl Petrol is best thing you can use to help get the stickers off / any left over adhesive Ahah, thanks Brian, I'll give it a try Was going to start using some chemicals but most don't react well with paint work Link to comment Share on other sites More sharing options...
Gaz6002 Posted August 2, 2008 Share Posted August 2, 2008 Ahah, thanks Brian, I'll give it a try Was going to start using some chemicals but most don't react well with paint work If that doesn't work mate there is a citrus based product called "sticky stuff remover" which works wonders. Link to comment Share on other sites More sharing options...
tDR Posted August 2, 2008 Share Posted August 2, 2008 Ahah, thanks Brian, I'll give it a try Was going to start using some chemicals but most don't react well with paint work Damp cloth, petrol (regular unleaded will do!) cover the stickers and let the petrol soak in with getting the stickers off as quick as you can to then rinse the area with water to avoid paint damage Link to comment Share on other sites More sharing options...
kosmic Posted August 4, 2008 Share Posted August 4, 2008 or nail polish remover...works a treat. just polish the paintwork after to remove any traces Link to comment Share on other sites More sharing options...
Guest CoolsBlue Posted August 4, 2008 Share Posted August 4, 2008 or nail polish remover...works a treat. just polish the paintwork after to remove any traces just make sure its not acetone nail polish or it will bite through the paint... Link to comment Share on other sites More sharing options...
Homer Posted August 7, 2008 Author Share Posted August 7, 2008 Just found this pic of both of my supra's together, way back in November 2003. What are the chances of that! The silver one is Dudes car, the black one is the one I bought from Paul Evans before joining here John had titled the photo "My toys" Link to comment Share on other sites More sharing options...
SteveR Posted August 7, 2008 Share Posted August 7, 2008 Mmmmm toys Link to comment Share on other sites More sharing options...
Homer Posted August 9, 2008 Author Share Posted August 9, 2008 Gav and I finally got the engine and box in today (in the rain!) It was a bit of a struggle, but with a bot of manuvering it dropped in eventually. Some pics of the rare sight of an NA engine being installed Forgot just how big a 2JZ is! We failed on this 1st attempt and had to take the hoist to it's furthest reach at the 1/2 ton mark to get the correct reach. It was times like this I'm thankful for a proper engine hoist! Gav doing the work while I stand around taking pics Once again a huge thanks to Justgav for giving up another afternoon to help out Link to comment Share on other sites More sharing options...
JamieP Posted August 9, 2008 Share Posted August 9, 2008 Well done mate, gotta be the first ever TT to ST to NA supra, not to mention auto to manual:) Link to comment Share on other sites More sharing options...
JustGav Posted August 9, 2008 Share Posted August 9, 2008 Gav and I finally got the engine and box in today (in the rain!) It was a bit of a struggle, but with a bot of manuvering it dropped in eventually. Some pics of the rare sight of an NA engine being installed More than welcome chap, was a good job done, should be relatively straight forward to get up and running now Link to comment Share on other sites More sharing options...
RedM Posted August 9, 2008 Share Posted August 9, 2008 Have I missed something? What happened to the plans for a V8 lump? Link to comment Share on other sites More sharing options...
Guest CoolsBlue Posted August 9, 2008 Share Posted August 9, 2008 Cool! im guessing its not wired up? Link to comment Share on other sites More sharing options...
