Cut Fiber Glass Guage PODs?
Jellybean
I used something similar to this:
http://i.ehow.com/images/GlobalPhoto/Articles/2001922/holesaw_Full.jpg
First I covered the area to be cut out with masking tape (for a cleaner cut) then made sure I had my center point correct for the drill bit and drilled at a medium speed very carefully :)
Edges where then tidied up with some sand paper.
Thanks, just finished. Came out better than I taught looks awesome
Duration : 2 hours with a metal File did the trick
Mask taped up the area then drilled out loads of holes first with the drill, used a small hack saw blade to join all the small drilled holes. This removed a lager portioon of the area, then I went to work on it it a circular metal file. Took some time but it worked
I was afraid to use a circular saw incase it cracked, so I took the longer route, taught it might be safer
