lee_kelsey Posted July 16, 2002 Share Posted July 16, 2002 Just wondering if any of you have had the experience of fitting the above BOV (or any bov for that matter!)? I have just ordered one, which is arriving this week and am wondering whether it is something I could fit myself? I am pretty competent when it comes to this kind of thing, and have changed air intakes, rads, brakes etc. before, but I am in no way a mechanic! Any advice/hints/tips would be appreciated. cheers Quote Link to comment Share on other sites More sharing options...
Andrew Posted July 16, 2002 Share Posted July 16, 2002 Fitted one last month, very easy to do. The only problem was squeezing the unit into place as some of the intake piping gets in the way. Quote Link to comment Share on other sites More sharing options...
lee_kelsey Posted July 16, 2002 Author Share Posted July 16, 2002 Originally posted by Andrew Fitted one last month, very easy to do. The only problem was squeezing the unit into place as some of the intake piping gets in the way. Great! So did it come with fitting instructions, or did you just work it out? Also what did you do about the stock bov, i.e. how did you block it off? (if you did at all!) cheers Quote Link to comment Share on other sites More sharing options...
Andrew Posted July 16, 2002 Share Posted July 16, 2002 You can see clearly here the small rubber blocker that shuts off the original hole. These pictures are taken from MKIV.COM Quote Link to comment Share on other sites More sharing options...
