chrisbilling Posted February 2, 2008 Share Posted February 2, 2008 Dear All, I want to fit 8.5x 18 et 40 on the Supra, with 225 tyres at front and 245 at back. Will this be inside the wheel arch's or cause problem. Whats sizes are you all running? Thanks Chris Quote Link to comment Share on other sites More sharing options...
Ian W Posted February 2, 2008 Share Posted February 2, 2008 ideally you want a wider rear wheel than the front. (i.e. 9.5j?) the offset isn't terrible but not stock. Tyre wise, your front is ok but i'd consider a 255 on the rear (though the 245 will fit). Shouldn't cause any problems with rubbing etc I don't *think*. Main concern would be that all wheels are the same width Quote Link to comment Share on other sites More sharing options...
merckx Posted February 2, 2008 Share Posted February 2, 2008 This fitment guide is useful, you can input your sizes. Most of us if buying aftermarket wheels would put wider wheels on the rear just like the stock car as Ian has already mentioned. But if you're set on buying 8.5" front and rear then in my opinion they wouldn't cause you any problems, the best tyre sizes would be (if using 18" wheels). 235/40 18 front 255/40 18 rear I've also taken into account of the stock tyre diameter so your tyres will fill the arches and your speedo won't be too far out. Best to get more than one or two opinions though.Supra Tyre fitment.xls Quote Link to comment Share on other sites More sharing options...
chrisbilling Posted February 3, 2008 Author Share Posted February 3, 2008 Thanks for all the advice. Will 9 x 18 ET 40 front 10 x 18 ET 40 rear Be too far out from the arch's??? My main concern is that the wheels dont come out further than standard Chris Quote Link to comment Share on other sites More sharing options...
Lee P Posted February 3, 2008 Share Posted February 3, 2008 If you go for 10 X 18 et40 rear they will sit 16mm futher out than stock so you should have no problems with fitment. Quote Link to comment Share on other sites More sharing options...
