Hurst Line Lock Kit
tooquicktostop
so i take it these replace the existing front brake lines?
Or rears? How easy to fit system?
I imagined a manual valve to stop rears getting pressure, If using for drag starts does it integrate electronically with launch control etc or does it manually release with the steering wheel button?
Knightrider
Knightrider,
These lines go up under the hood right around the brake master cylinder. They take the front lines and route them through the line lock control solenoid, then back to the master cylinder. Its a push button type trigger that the driver releases or engages.
Does this help some?
  • 4 weeks later...
I have some more of these in stock if your or anybody else is interested.
Cheers
Hi Kyles, I am ready to buy the line lock now so pm me your paypal and i will sort it..Providing they are still readilly available and in stock?
Cheers
ok firstly it says not campatible with ABS, I have ABS :(
Also can anyone tell me which of the scematic diagrams in the instructions relate to the supra?
After reading the instructions it seems the system works when the driver depresses the brake then actuates the line lock, a dash light tells you its engaged and it holds the front brakes for 60 seconds, until solenoid gets too hot, so then you have to manually release it.
I am also running RLTC how will this affect me? I guess i will turn it off for burn out then on again for the drag run??
Hope that clarifies
  • 1 month later...
Finally got around to fitting this, The solenoid has 1 inlet and 3 possible outlets, Does anyone know does it go before or after the ABS unit?
I have found the 2 lines from the master cylinder but they both go into the abs unit, I also id'd the 2 lines coming out to each front brake but the problem i cant sus is which lines to i plug/use etc arrrrgh?
Please Help
