LED Rear Lights
heckler
Right.
LED Rear lights -
I have now made a few set (all sold before you ask) And there available in various options.
Plug and play
The Plug and play version will be wired to include a fog light (UK) -so you will have to conect that up to your car
PCB only
The second version, you will have to split the lights, remove the old lenses, fit the PCB/LED's, seal back up then adapt your wire loom , again FOG light for the UK
FULL LED (as per my car, or JSpec pattern) £450 (£350 PCB's)
TS Style (just rings) with full LED reverse light £300 (£200 PCB's)
TS Style (just rings) with ring reverse light £275 (£175 PCB's)
TS Style (just rings) with stock reverse light £250 (£150 PCB's)
Judging from the remarks made at ACE Cafe, the FULL TS style (4 LED rings) was prefered over the ones on my car.
I can do any pattern, i.e. JSpec, UK, Hybrid (like mine) etc.. just ask
On top of these prices, a set of lights will need to be provided WITH loom, or I can supply for extra at going rate.
If your interested in them, I will require a deposit to cover the initial cost of buying the raw materials.
The deposit will be £100 - which will give you a rough Idea on how much the raw materials cost.
ALL of the lights are Road Legal - i.e. they have reflectors mounted in the indicator. My Car has passed an MOT with them on. The reflector looks very bright, this is due to the flash. trust me.
  • 3 weeks later...
Sorry if this is a stupid question Si, but how does this all work with wiring up the fogs, and where would that be? In the centre of one of the rings?
I can put the fog light where ever you want it! - I normally put it as one of the centers of the rings, which is also a brake light if you want. The pics are of my light off er, my car - which is a UK/Jap hybrid mix i.e. 1 brake 1 side light (in one cluster) and the other cluster is the fog light.
