Bryson Posted January 29, 2008 Share Posted January 29, 2008 Just noticed that when I reverse my supra auto there is a knocking/clicking noise from the back drivers side wheel on every full turn, could this be that it is needing dif oil and if so where do I check, or could it be something else? This only happens in reverse but is fine when in drive. Cheers Quote Link to comment Share on other sites More sharing options...
turbonut Posted January 29, 2008 Share Posted January 29, 2008 Might be an idea to get your rear suspension checked out, could be worn bushes or something loose, or maybe general wear and tear. Hope you find the cause. L Quote Link to comment Share on other sites More sharing options...
Bryson Posted January 29, 2008 Author Share Posted January 29, 2008 didnt know that the suspension could cause the clicking noise Quote Link to comment Share on other sites More sharing options...
Ian R Posted January 29, 2008 Share Posted January 29, 2008 I had a clicking noise on my supe. It was just one of the studs in the brake calliper had worked loose and was clipping the wheel. Might not be this but worth a look anyway Quote Link to comment Share on other sites More sharing options...
