Tyres again
SexySallySupra
the reason for not having same width allround is that the Supra was designed to handle with larger width rear tyres relative to the front. Larger width helps with lateral grip forces when cornering. The grip balance of your Supra will not be as what it was designed to be if you've got same width allrond.
Standard setup for a TT is 255 rear and 235 front. Lots of guys widen their tyres for extra corner grip, and usually go for 245 or 255 front width, and 275 or 285 rear width. But you'll obviously have to have the correct rim width to support these tyres.
