SexySallySupra Posted January 15, 2005 Share Posted January 15, 2005 I want to run some 235/35/18 fronts and 265/35/18 on the rear, what would be a good size alloy for this setup? 9.5/18??? Link to comment Share on other sites More sharing options...
Scooter Posted January 15, 2005 Share Posted January 15, 2005 firstly i think you want 235/40/18's for the front. as for wheels widths you want at least 8" front 9" rear's. 9.5's will be fine for the rear, but you don't want the same width all round. Link to comment Share on other sites More sharing options...
merckx Posted January 15, 2005 Share Posted January 15, 2005 but you don't want the same width all round. Any particular reason? I've got 255/35/18 all round, the car came like this. Would like to get some wider ones on the back but I don't think the wheels are wide enough. Link to comment Share on other sites More sharing options...
Guest Dave_Refault Posted January 16, 2005 Share Posted January 16, 2005 Tramline nightmare I should imagine Link to comment Share on other sites More sharing options...
merckx Posted January 16, 2005 Share Posted January 16, 2005 Tramline nightmare I should imagine It drives really well, I would like to get some wider ones for the back though! Link to comment Share on other sites More sharing options...
AJI Posted January 17, 2005 Share Posted January 17, 2005 the reason for not having same width allround is that the Supra was designed to handle with larger width rear tyres relative to the front. Larger width helps with lateral grip forces when cornering. The grip balance of your Supra will not be as what it was designed to be if you've got same width allrond. Standard setup for a TT is 255 rear and 235 front. Lots of guys widen their tyres for extra corner grip, and usually go for 245 or 255 front width, and 275 or 285 rear width. But you'll obviously have to have the correct rim width to support these tyres. Link to comment Share on other sites More sharing options...
