spiderpigcity Posted January 27, 2008 Author Share Posted January 27, 2008 just gonna double check, but im sure only one cat there at front under turbo Quote Link to comment Share on other sites More sharing options...
spiderpigcity Posted January 27, 2008 Author Share Posted January 27, 2008 no 2nd decat, just a 4 inch pipe all the way throught to back joint then through to back box. there is a big bolt screwed into the pipe just uunder the drivers seat, maybe for a sensor to be fitted maybe? regards matt Quote Link to comment Share on other sites More sharing options...
spiderpigcity Posted January 28, 2008 Author Share Posted January 28, 2008 the first one in the photo (block this off) leads to the other end where you have marked the red cross, that then branches off the the other pipe. so in other words they are joined together and are not connected at either end as in photo. therefore showing 1 pipe (block this off) at one end , and two pipes at the other end as in the photo. too sum it up the pipes are only 12 inches long and are disconnected at both ends so they dont lead anywhere, thats why they arnt blocked off. basically just two pipes sat there doing nothing. i presume this is because the hks bov has been fitted. as for the black blocked pipe that has the yellow tie wrap around it, i dont know what that does, it leads to a big body of some sort. Quote Link to comment Share on other sites More sharing options...
spiderpigcity Posted January 28, 2008 Author Share Posted January 28, 2008 ive followed the pipes and they dont lead anywhere check the pictures out. regards matt Quote Link to comment Share on other sites More sharing options...
spiderpigcity Posted January 28, 2008 Author Share Posted January 28, 2008 pics Quote Link to comment Share on other sites More sharing options...
spiderpigcity Posted January 28, 2008 Author Share Posted January 28, 2008 pic Quote Link to comment Share on other sites More sharing options...
JohnnyW Posted January 28, 2008 Share Posted January 28, 2008 1st CAT's the small one, 2nd CAT's the longer one. Quote Link to comment Share on other sites More sharing options...
spiderpigcity Posted January 28, 2008 Author Share Posted January 28, 2008 def only got the short one. no 2nd cat, is that bad? Quote Link to comment Share on other sites More sharing options...
spiderpigcity Posted January 28, 2008 Author Share Posted January 28, 2008 there is another soloniod valve disconnected near steering pump near 2nd turbo. is that cos its got hks bov? Quote Link to comment Share on other sites More sharing options...
Nic Posted January 28, 2008 Share Posted January 28, 2008 def only got the short one. no 2nd cat, is that bad? The 1st cat is the most restrictive of the 2, if you are going to up the boost to 1.2bar then I would definitely remove this otherwise your exhaust temps could get dangerously high. Quote Link to comment Share on other sites More sharing options...
Nic Posted January 28, 2008 Share Posted January 28, 2008 Matt it is very confusing posting about the same subject in multiple threads. The car will be a lot more responsive and spool up quicker with the first cat removed. Quote Link to comment Share on other sites More sharing options...
JohnnyW Posted January 28, 2008 Share Posted January 28, 2008 Matt it is very confusing posting about the same subject in multiple threads. Agreed, there was about 3 or 4 threads on it when I posted those pics! Looks like one of the mods have merged them together. Try and keep the threads down mate or it gets really messy. Quote Link to comment Share on other sites More sharing options...
Kranz Posted January 28, 2008 Share Posted January 28, 2008 Agreed, there was about 3 or 4 threads on it when I posted those pics! Looks like one of the mods have merged them together. Try and keep the threads down mate or it gets really messy. Attempting to sort it out! Quote Link to comment Share on other sites More sharing options...
Steve Posted January 28, 2008 Share Posted January 28, 2008 Attempting to sort it out! Good luck Quote Link to comment Share on other sites More sharing options...
Wez Posted January 28, 2008 Share Posted January 28, 2008 I think you should read this FAQ on the sequential operation as you could be running in TTC. http://www.mkivsupra.net/vbb/showthread.php?t=35926 This would explain the lack of sub 4000rpm pull which is normally where the 2JZ-GTE shines. Quote Link to comment Share on other sites More sharing options...
Wez Posted January 28, 2008 Share Posted January 28, 2008 What is the carbon inline canister on your inlet pipe? Quote Link to comment Share on other sites More sharing options...
spiderpigcity Posted January 28, 2008 Author Share Posted January 28, 2008 don't know. just got the car 2 days ago. one of many mods that i havnt got a clue about? regards matt Quote Link to comment Share on other sites More sharing options...
Steve Posted January 28, 2008 Share Posted January 28, 2008 don't know. just got the car 2 days ago. one of many mods that i havnt got a clue about? regards matt Did you not get any info on the car before buying it to see what was fitted? Quote Link to comment Share on other sites More sharing options...
spiderpigcity Posted January 28, 2008 Author Share Posted January 28, 2008 Did you not get any info on the car before buying it to see what was fitted? yeh a bit, but i wasnt too bothered cos i just bought it to run a round in for a bit (without sounding like a knob) Quote Link to comment Share on other sites More sharing options...
Steviekid Posted January 29, 2008 Share Posted January 29, 2008 You can see what's going on with your sequential pipework better with those closeup pics. Your exhaust gas bypass valve has been completely removed from the equation. The pressure feed from the pressure tank has been blocked off so you won't be losing anything from the pressure tank. Because all the pipes have been disconnected, then the fact the pressure dump from the original wastegate VSV isn't blocked off doesn't really matter. In summary, if you're running in TTC which it sounds like, then stopping the EGBV working doesn't make any difference and you're ok as you are. If you're running in sequential then I'd hook it back up again and block off the other pipe. Quote Link to comment Share on other sites More sharing options...
