Blue smoke in the morning
Neil Sandham
Folks,
As the engine starts up in the morning, just for a couple of seconds I get blue smoke from the exhaust then after that everything is fine. There is no excessive oil consumption and the engine pulls just fine. If I startup it up later in the day (engine probably still warm) then everything is normal.
Any ideas ?
cheers
Neil.
Originally posted by Neil Sandham
definately not steam !
Valve stem seals ties in with my thinking. But wasnt sure if the same theory (ie when cold over night the oil can seep past the seals) also applied to the turob oil seals.
cheers
Neil.
I concur, valve stem seals, almost certainly the exhaust ones. They go first due to them running a LOT hotter than the intake ones.
Turbo seals usually only give smoke AFTER the engine is hot, they leak into the exhaust, effectively, and need that region to be mad hot to turn the oil into visible smoke. I usually find a turbo seal problem gives "oilier smelling" smoke than ring problems, the oil in the combustion chamber sees much higher temps than when it just leaks into the manifold. YMMV :-)
hmmm.If it was the valve stem seals it would smoke when it was started warm or cold wouldnt it.They do go hard and britle.But to state the obvious u said that u were not loosing any oil.Can u get some one else to start it in the morning for u and smell it.U will easy tell if its oil been burned.
It would depend how bad the seals were. If the car is still for some time even with only slightly damaged seald the oil has time to get past. If theseals are buggered then it won't matter how long your engine isstill the oil just runs past the seals.
If you have only one or two seals going, you may not get oil burn after every cold start. AIMHO
But to state the obvious u said that u were not loosing any oil. [/b]
The only oil consumption is what I would consider normal ie about half a litre every 5 or 6k miles. The blue smoke in the morning isnt a huge cloud just whispers, but noticeable non the less. I guess its just the symptoms of problems beginning rather than a full blown (pardon the pun) failure. By Supe has done just under 100k miles btw.
cheers
Neil.
cheers
Neil.
That oil consumption is REMARKABLY good, I wouldn't worry about it at all.
Originally posted by Barry
Mine has not used any oil in the 3k miles I've done so far, but I'll be treating it to a new filter and oil change this weekend.
good luck with the damn filter change !
Chris W. (or anyone)- if you're still listening in, i've got big oil consumption on my old mk2 Golf. Think it's oil stem seals too. 16yrs old, 114k miles.
Question #1 : Is it fine to just leave it, and keep topping up with oil ?
Questions #2 : Do those "Stop Smoke" oil additives work ? (asi might need to do something to get it thru the MOT due to smoky exhaust).
Questions #3 : Can they fail a car for MOT due to a slightly smoky exhaust ? Or is it only gas emissions that they check for ?
sorry for slight hijack. Oil seal related...
