Digsy Posted July 11, 2002 Share Posted July 11, 2002 Teabreak quickie: Is there any way to plug something into the diagnostic port that will tell me what gear my all-knowing autobox ECU has selected, in real-time while I am driving? TIA, Link to comment Share on other sites More sharing options...
Ian C Posted July 11, 2002 Share Posted July 11, 2002 There are gearlevel position pins on the ECU. These are probably set by the lever position, as it covers park, neutral, etc. as well as L, 2, and Drive. Still worth seeing if they are set by the autobox as it changes gear as well, though. -Ian Link to comment Share on other sites More sharing options...
Digsy Posted July 11, 2002 Author Share Posted July 11, 2002 Originally posted by Ian C Still worth seeing if they are set by the autobox as it changes gear as well, though. Cheers, Ian. Thats what I'm looking for. Do you know the pins, or should I dig through MKIV.com? Link to comment Share on other sites More sharing options...
Ian C Posted July 12, 2002 Share Posted July 12, 2002 Here are the relevant ones: Terminal E10 3 - Kickdown 7 - Reverse 9 - 2nd 10 - Low 18 - Manu mode 28 - Overdrive main switch Terminal E9 9 - A/T no2 solenoid 10 - A/T no1 solenoid 12 - A/T solenoid SLT (no idea what SLT is) 13 - A/T no4 solenoid 14 - A/T no3 solenoid 31 - A/T solenoid SLT 76 - Park/neutral position sensor Strangely, there doesn't appear to be a line for Drive! That's probably the default state of the system, i.e. if no other lines are active. -Ian Link to comment Share on other sites More sharing options...
Dragonball Posted July 12, 2002 Share Posted July 12, 2002 Just have to say guys that, in all seriousness, I am in awe of the info that you can come up with about your cars! Credit where it's due - it really is quite refreshing to find people who have real passion about something Nuff said - no bull Paul:cool: Link to comment Share on other sites More sharing options...
