N/A 0-60 cant find it anywhere!!!!
ben_stevo
  • Replies 288
Im no youngster...sunny Jim..;) .
How old are you then ? I dont mean to sound funny or anything but your posts dont seem to be written by an Oldie :D.
The words/phrases highlighted below just dont seem to have come from anyone older than about 20. And thats not old.
As far as mods go, im running 18" wheels with 265/35/18's on the rear, 2nd decated with 5" stainless steel exhaust and HKS filter... nothing special. But the engine is so smooth and runs like new, very responsive. Last week I beat a WRX turbo all the way to 120 leptons off the line with him chasing on my rear arch until I backed off. It seems to draw a lot of attention at night. Don't get me wrong, I don't go out racing every night, or thrash my car about, generally I drive very safely and just cruise along. I felt I had to do this 0-60 test because I would have been really disappointed if it did it in 7 seconds.
Two of my cousins have WRX turbo's and they are quite fast, my bimma eats them for lunch.:p This one may have been a dudd one, if so, the guy in the scooby lied to me....
So come on, lets know how old you are. It may not add much credability to your claims , but in a funny sort of way some people just trust what older people say, because they know that older people were young once and have learnt from past mistakes. Basically what im saying is that generally younger people tend to blag/brag more than old people.
A bit of evidence to back up the very low 0 to 60 claims wouldnt go a-miss either.
I got an NA auto and a 6 speed single, the NA is great for going shopping and getting to work :p
I've owned an n/a, stock uk tt, full bpu & T04R all autos and each one a world apart from the other, I will say that i think a lot of n/a owners live in a dream world with some of the performance figures that they come out with, my n/a couldn't beat 330ci's, yet my stock tt could pull away from M3's and BPU it was much quicker than a M3.:)
I've owned an n/a, stock uk tt, full bpu & T04R all autos and each one a world apart from the other, I will say that i think a lot of n/a owners live in a dream world with some of the performance figures that they come out with, my n/a couldn't beat 330ci's, ''yet my stock tt could pull away from M3's'' and BPU it was much quicker than a M3.:)
Quote ''Even an Evo M3?'' - i got beat the other day - he couldn't have been stock, but i did have two fat buggers in the car with me, so probably another 200kg! He only pulled away a little, but thought i would have over taken!! To say i was disappointed is an understatement!
you must have one of the quickest N/A's around to reach that time
i was on a meet yesterday and i can tell you i got leatherd by4 TT from a start and a stock TT does around a 5 sec 60mph time and i was a good 2 sec behind them
so unless it has nos or a heavly modded motor it just aint poss
Brett had a similar run in with a tt lol!:D
Sounds a bit quick for an n/a though, also had another test between a tt and an n/a coming off the lights onto a slip road, as soon as number 2 comes in he was toast, so good 1-2 seconds behind...
Type 2+2 FHC
Designer
Number of doors 2
dimensions & weight
Wheelbase 2550 mm 100.4 in
Track front 1520 mm 59.8 in
rear 1525 mm 60 in
Length 4520 mm 178 in
Width 1810 mm 71.3 in
Height 1275 mm 50.2 in
Length:wheelbase ratio 1.77
Ground clearance 130 mm 5.1 in
Kerb weight 1430 kg 3153 lb
Weight distribution
(Front)
Fuel capacity 70
litres 15.4
UK Gal 18.5
US Gal
aerodynamics
Drag coefficient
Frontal Area
Cx
engine
Code
Manufacturer Toyota
Type S-6
DOHC
24 valves total
4 valves per cylinder
Main bearings
Construction
Bore × stroke 86.00mm × 86.00mm
3.39 in × 3.39 in
Bore/Stroke ratio 1
Displacement 2997 cc
(182.888 cu in)
Unitary capacity 499.5 cc/cylinder
Compression ratio 10.00:1
Fuel system EFi
Aspiration Normal
Compressor type N/A
Intercooler None
Catalytic Converter Y
Max. output
(JIS) 228.1 PS (225.0 bhp) (167.8 kW)
@6000 rpm
Max. torque
(JIS) 284.0 Nm (209 lbft) (29 kgm)
@4800 rpm
Maximum rpm
Coolant Water
Specific output 75.1 bhp/litre
1.23 bhp/cu in
Specific torque 94.76 Nm/litre
performance
Note: A value of -1 means that
the car cannot attain that speed.
0-50mph (80 km/h)
0-60mph 5.9s
0-100km/h
0-100mph
80-120km/h
(50-70mph)
in top
0-Quarter-mile
0-Kilometre
Top speed
Fuel Consumption
CO2 Emissions
Carfolio Calculated CO2 ?
Power-to-weight 157.34 bhp/ton
Type 2+2 FHC
Designer
Number of doors 2
dimensions & weight
rear 1525 mm 60 in
Weight distribution
(Front)
Fuel capacity 70
litres 15.4
UK Gal 18.5
US Gal
aerodynamics
Drag coefficient
Frontal Area
Cx
engine
Code
Manufacturer Toyota
Type S-6
DOHC
24 valves total
Main bearings
Construction
3.39 in × 3.39 in
Bore/Stroke ratio 1
(182.888 cu in)
Fuel system EFi
Aspiration Normal
Compressor type N/A
Intercooler None
Max. output
@6000 rpm
Max. torque
@4800 rpm
Maximum rpm
Coolant Water
1.23 bhp/cu in
performance
0-50mph (80 km/h)
0-60mph 5.9s
0-100km/h
0-100mph
80-120km/h
(50-70mph)
in top
0-Quarter-mile
0-Kilometre
Top speed
Fuel Consumption
CO2 Emissions
This site was not complete
I think we all new that any way but that was not his question.
I am answering the original question
Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,Its not 5.9,
my N/A is 6s so not far off that 5.9s iv got a video im trying too post it up
