cheekymonkey Posted January 24, 2008 Share Posted January 24, 2008 I have a HID conversion in my car that was there when I got it, maybe even had been done in Japan. I've noticed that when I get home after a nice long drive, the right hand light isn't on, even though it turned on OK at the start of the journey. If I then turn the lights off, and on again, *sometimes* it's OK, but most of the time it fails to light - you'll get the HID "startup" flash but then nothing. I've tried tapping, waggling and prodding the ballast wires, I don't think it's a bad connection. Is this likely to be a bulb or the ballast on it's way out? Quote Link to comment Share on other sites More sharing options...
Ian R Posted January 24, 2008 Share Posted January 24, 2008 faulty ballast pack had similar had to replace it Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted January 24, 2008 Author Share Posted January 24, 2008 OK, do you know if these ballast packs are fairly universal? I bought my brother a HID upgrade for his Evo IV for xmas, yet to be fitted, so might be able to borrow the ballasts Quote Link to comment Share on other sites More sharing options...
merckx Posted January 24, 2008 Share Posted January 24, 2008 More likely to be the ballast if you're connections are okay. :idea:You could always swap the bulbs and then swap the ballasts to establish where the fault is. Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted January 24, 2008 Author Share Posted January 24, 2008 :idea:You could always swap the bulbs and then swap the ballasts to establish where the fault is. Ah, yes, since I didn't think of that I think it must be time to go to bed Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted February 4, 2008 Author Share Posted February 4, 2008 Hey chaps I have isolated the fault to the bulb itself, swapped the ballasts and the problem remains. I then swapped the bulbs to make sure it wasn't the car's loom but the problem definitely followed the bulb. Couple of pics attached - can I get the bulbs separately? I don't want to get a whole new kit as the ballasts are fine. Quote Link to comment Share on other sites More sharing options...
