cam belt tensioner
123tom123tom
the tensioner is just a long hydraulic piston that pushes onto the idler gear to give it tension. and thats what the belt runs on.:)
remove the drivebelt (alternator belt) first and run the engine up just to make sure the noise is coming from within the timing cover.
Mine started to rattle which ended up being the alternator belt tensioner, so decided it was a good indicator to get everything changed up front.
I got the timing belt and tensioner and alternator belt and tensioner changed and all bits supplied main dealer (Steve Manley - 01865 291300 or [email protected]) he will sort you out a good deal.
