my TV has gone pop
supra steveo
its a rear projection tv a Bush one
and no it doesnt respond to a good kicking, ive just ran across the room and volleyed it about 10 times so if it wasnt broken it probibly is now
:D I know how you feel my tv did the same just before xmas and It got a good thrashing for its troubles too.
Rear projection? I'd not give them a thump, as I thought they had bulbs in similar to a front projection.... expensive stuff.....
I had a problem with my old tv whereby the whole image was in 1 line across the screen, I found it to be a dry joint on one of the IC's on the board. I'm racking my brain as to which IC.... but the only one I can think of is the chroma IC and that's colour, not picture.....
Be careful if you do attempt anything though - some VERY large voltages inside TV's, steer clear of any capacitors!
