Weird sound from the engine? Tech people help pls!
randy
I hear a weird short 1 sec sound like {metal buzz} that comes when I floor my car gradually say on 2nd gear between 5000 RPM TO 6500 RPM I can also feel the viberation in the accelerator pedal. There is no loss of power! Also when I floor on WOT this sound does not come. Help pls! :(
I had a resonating sound at certain rpm turned out that one of the exhaust hangers was off and the exhaust was resonating. If it only happens at a certain rpm it sounds like something is loose and vibrating.
HTH
I used to get this when I had my Apeci Downpipe on, but not now I have my Mongoose system.
I think this metallic noise is only being generated by the harmonics of the exhaust system. Mine originally sounded like a bag of nails were loose in the pipe, did 25Kmiles without any problem, then fitted a complete replacement exhaust and it's all gone. So it must have been the exhaust material or construction.
Pete
