Anyone able to write serial PDA applications
Wez
  • Replies 90
Nice one... what dev suite are you using?
MS eMbedded Visual C and Windows Mobile 2003 SDK with an emulator.
I managed to find an app yesterday called Commlog which is a serial monitor that runs on the PDA. I am now looking for a serial emulator that will allow me to play a capture back from the PC to the PDA, it would make development a lot easier.
I did a serial capture of the telemetry output on the AEM today and this should be pretty easy. The AEM supports upto 19 feeds for telemetry, for testing I have captured just 1 and 2 data feeds.
With 1 feed the stream length is 3 bytes, Header byte, stream data, checksum byte.
Here is a datastream for throttle position using 1 feed.
55 00 00 55 09 09 55 15 15 55 21 21 55 2E 2E 55 3D 3D 55 4D 4D 55 5E 5E 55 6D 6D 55 7E 7E 55 8F 8F 55 A0 A0 55 B0 B0 55 BC BC 55 C8 C8 55 D5 D5 55 E1 E1 55 EC EC 55 F7 F7 55 FF FF 55 FF FF
55 - header byte
?? - data
?? - checksum
All we have to do is convert the data byte into decimal and multiply by the scaler which for throttle % is 0.390625
09hex/09dec x 0.390625 = 3.52%
2Ehex/45dec x 0.390625 = 17.97%
6Dhex/109dec x 0.390625 = 42.58%
I will add the 2 feed datastream later :D
Are you doing this to provide additional in car monitoring tools for daily and track use? Seems a lot of work for development and tuning purposes where the aem software on a laptop would be usable. Would an in car double din PC with a dash mounted monitor not be a better solution for this application instead of trying to bodge up and mount a PDA? Guy I will shortly be working with again put a PC in his 300zx displaying alot of his ecu's outputs on an LCD screen that he configured himself.
Yes :D
Its just a monitoring tool, the AEM gauge only shows one item at a time, with this I could do away with any additional gauges.
Having a PC in the car is not really an option.
A PDA connected directly to the ECU using the telemetry output would be ideal for my application.
Why is having a double din pc in your car not an option? You are bound to have a stereo in there right? Its only absorbing the same space as that. It can still play cds and be a radio (I think) and has an output to a screen. That for sure will provide a hell of a lot more scope than a fudged PDA application for 2003.
Ok back on topic :D
Here is a 2 feed data stream, the length is now 4 bytes, Header byte, stream data (2bytes), checksum byte. I am using batt volts for data field 1 and throttle % for data field 2.
55 B9 7E 37 55 B9 97 50 55 B9 B5 6E 55 B9 D2 8B 55 B9 ED A6 55 B9 FF B8 55 B9 FF B8 55 B9 FF B8
55 - header byte
?? - data - batt volts
?? - data - throttle %
?? - checksum
We convert the data byte into decimal and multiply by the scalers in the same way.
* batt v = 0.062500
* throttle % = 0.390625
The voltage is low as this was done with the engine off.
B9hex/185dec x 0.062500 = 11.56v
7Ehex/126dec x 0.390625 = 49.22%
The AEM supports 19 output channels which are configurable.
Now I just need to right an app to take this information and display it :D
Yes you can access the parameters in the AEM software which only loads on a full blown PC not a PDA.
AEM wont release the serial datastream, I am using the serial gauge output for this.
I am looking for a PDA version of the gauge-tech unit, everyone thought they were a good idea :shrug:
An example of what I plan to monitor :D
Engine Speed
Engine Load
Throttle
Air Temp
Coolant Temp
Injector Duty
Gear Calculated
Battery Volts
Ign Timing
Vehicle Speed
Run Time
Boost Target
Logging
O2 #1
O2 #2
O2 FB Status
Knock #1 Volts
Knock #2 Volts
EGT
The list to choose from is huge but once the app is done it just a matter of changing the scaler for that byte reference.
OK so thats no help in translating the parameters to a PDA application then? Would a program thats similar to the one I know a work chappy has in his 300zx for gauge displays help?
Not sure I know what you mean.
As I have done the serial trace and know how the datastream is assembled the info in the AEM application makes perfect sense. I dont forsee the need to do anymore serial captures to finish the app.
Nice work there Wez... seems that you are making quite good progress...
Although I'm working in VB, anything you need to ask, ask away.. :)
When I'm on night's I'll be looking if I can get something to play the stream from a file on a PDA, will that be useful?
Also is the stream split at all, IE like a GPS stream into lines, or just one long stream?
PS, where did you get the scalers from?
My PDA serial cable arrived today, I have succesfully tested serial comms from my laptop to the PDA. I ran hyperterm on the laptop and Commlog on the pda which showed the data I was sending.
Just need to test it on the car now.
