Wez Posted January 21, 2008 Share Posted January 21, 2008 Hey All, Just wondering if there is anyone here who could write a simple serial PDA application. Would it be possible to use a serial monitor to capture the data between a laptop and AEM to get enough information to write a PDA monitor? http://www.serial-port-communication.com/serial-monitor/ Link to comment Share on other sites More sharing options...
Wez Posted January 21, 2008 Author Share Posted January 21, 2008 Some info here on how to open a serial comms from MSDN. http://msdn2.microsoft.com/en-us/library/aa454063.aspx Link to comment Share on other sites More sharing options...
MrRalphMan Posted January 21, 2008 Share Posted January 21, 2008 Hi Wez, I use serial comms in my GPS app. What exactly are you after? Just a complete capture of the input on a serial port? Shouldn't be too hard to do. Let me know what you need, but it might take a little while working around the kids and work.. Paul Link to comment Share on other sites More sharing options...
Wez Posted January 21, 2008 Author Share Posted January 21, 2008 I am looking for a small app to monitor some parameters on the AEM ECU. AEM wont release the datastream but I dont see why we cant use a serial sniffer to log what is being transfered. Hi Wez, I use serial comms in my GPS app. What exactly are you after? Just a complete capture of the input on a serial port? Shouldn't be too hard to do. Let me know what you need, but it might take a little while working around the kids and work.. Paul Link to comment Share on other sites More sharing options...
MrRalphMan Posted January 21, 2008 Share Posted January 21, 2008 How are you going to hook the PDA to the data stream? Capturing the data will be no issue, but you need to hook it up first.... The is a PDA app and not on the laptop? Link to comment Share on other sites More sharing options...
Wez Posted January 21, 2008 Author Share Posted January 21, 2008 I am trying to find an rs232 adapter for a PDA. The new IPAQ 314 looks nice with decent screen res 800x480, usb and built in GPS receiver, still looking to see if its possible to connect a USB to rs232 adapter to it. EDIT: just to be clear, I was going to use the PC app AEM Pro on a laptop to capture the datastream and then look at writing a seperate app on a PDA to view certain parameters. Link to comment Share on other sites More sharing options...
Wez Posted January 21, 2008 Author Share Posted January 21, 2008 It is proving a bit tricky to find a Palm or Ipaq that has serial comms, shame You can get CF to RS232 adapters but even finding an IPaq with CF now is not easy. Ideally something that would work with a cheap adapter on the lowest/cheapest model palm would be best but I dont think its possible. Link to comment Share on other sites More sharing options...
SimonB Posted January 21, 2008 Share Posted January 21, 2008 You can download an app to run on the laptop that will intercept what is going to/from the serial port. No need for a PDA app. Can't remember the name of the one I used, but it was freeware. Interpreting what it logs is likely to be harder than you think though - I expect the laptop software will send requests for data as well as just receive things. EDIT: Think it was called advanced serial port monitor. Link to comment Share on other sites More sharing options...
Jake Posted January 21, 2008 Share Posted January 21, 2008 SysInternals PortMon ? Link to comment Share on other sites More sharing options...
Wez Posted January 21, 2008 Author Share Posted January 21, 2008 Capturing the data isnt the prob, its finding a suitable cheap PDA on which to develop a monitor. The AEM has two serial modes, telemetry output and normal, normal is what is used by the AEM Pro software, Gauge Tech display and digital displays. Telemetry output is for the AEM serial gauge. Here is some AEM telemetry output info, the items to monitor can be selected in calibration. Byte Name Units Scalar Offset Min Max Signed? Bitmask 1 Engine Speed rpm 100 0 0 25599.60938 n - 2 Engine Load kPa 1.346484 0 0 344.69476 n - 3 Throttle % 0.390625 0 0 99.99847 n - 4 Air Temp C 1 0 -128 127 y - 5 Coolant Temp C 1 0 -128 127 y - Serial Port Settings Transmission sequence : Header byte, stream data, checksum byte Header byte : 0x55 Baud rate : 19200 Parity : Ignore Data size : 8 bits Stop bits : 1 Stream size : 21 Checksum : standard data sum Telemetry disabled Link to comment Share on other sites More sharing options...
Wez Posted January 21, 2008 Author Share Posted January 21, 2008 Interestingly there are plenty of ODBii tools for WinCE and PalmOS so its not impossible. Link to comment Share on other sites More sharing options...
Wez Posted January 21, 2008 Author Share Posted January 21, 2008 Some info from the Palm developers kit 14.2.2 Serial interface hardware Pins 10 and 11 provide 3.3V logic-level serial connections with no dedicated hardware flow control pins. The direction of these pins with respect to the device is as follows: ■ Pin 10 transmits from the handheld ■ Pin 11 receives into the handheld. The serial port connected to pins 10 and 11 supports the following bit rates and configuration options: ■ 1,200 baud ■ 2,400 baud ■ 4,800 baud ■ 9,600 baud ■ 14,400 baud ■ 19,200 baud ■ 28,800 baud ■ 38,400 baud ■ 57,600 baud ■ 115,200 baud ■ 7 data bits ■ 8 data bits ■ No stop bits ■ 1 stop bit ■ Parity bit ■ No parity bit Both pins 10 and 11 are pulled high within the device by weak pull-ups. For more information on how these weakly pulled, high input characteristics are used in the peripheral detection mechanism, see Section 14.4 on page 278. Pins 10 and 11 operate at 3.3V nominal voltage levels. Treo 650 smartphones, Tungsten T5 handhelds and E2 handhelds, and LifeDrive mobile managers are designed to accept the following parameters on pins 10 and 11: (V)RXTX_INL Input logic low voltage* 0 - 0.594 V (V)RXTX_INH Input logic high voltage* 2.904 - 3.63 V (V)TX_OUTL Output logic low voltage* 0 - 0.3 V (V)TX_OUTH Output logic high voltage* 2.67 - 3.63 V (V)TX_OC Open circuit TX line voltage* - 3.3 - V (V)RX_OC Open circuit RX line voltage* - 3.3 - V Link to comment Share on other sites More sharing options...
MrRalphMan Posted January 22, 2008 Share Posted January 22, 2008 My Dell Axim X50v is VGA and has a CF slot, might be worth looking for one of these? So you're not trying to capture the data, just to display some of the outputs? Link to comment Share on other sites More sharing options...
Wez Posted January 22, 2008 Author Share Posted January 22, 2008 So you're not trying to capture the data, just to display some of the outputs? Correct. In the AEM software you can configure the telemetry output to just one and then select what you want to monitor, ie knock volts #1. We could do this for all the channels we want to monitor to capture the stream and then add multiple channels upto 19 in total. Link to comment Share on other sites More sharing options...
MrRalphMan Posted January 22, 2008 Share Posted January 22, 2008 Ok, sounds pretty simple. If you've an idea on how you want it to look? How configurable.... If you want graphical display or just text. A list of the output and what the values relate to would be good. You gotta remember I know nothing about the AEM kit. Link to comment Share on other sites More sharing options...
Wez Posted January 22, 2008 Author Share Posted January 22, 2008 Something like this would be great. #1 #2 #3 Link to comment Share on other sites More sharing options...
Wez Posted January 22, 2008 Author Share Posted January 22, 2008 I think to start with just a simple text based output would be ideal and possibly look into adding more features later. Link to comment Share on other sites More sharing options...
MrRalphMan Posted January 22, 2008 Share Posted January 22, 2008 If you have an example feed with the relevant parts you need, send it to me and I'll have a look. Link to comment Share on other sites More sharing options...
Wez Posted January 22, 2008 Author Share Posted January 22, 2008 If you have an example feed with the relevant parts you need, send it to me and I'll have a look. I will try and get a capture for you tomorrow Link to comment Share on other sites More sharing options...
Guest dejacky Posted January 22, 2008 Share Posted January 22, 2008 I have a Dell Axim X51 and AEM EMS so, I can test this and report results as necessary. Great work so far lads! Link to comment Share on other sites More sharing options...
Wez Posted January 25, 2008 Author Share Posted January 25, 2008 I have been working some crazy hours the last few days so will hopefully have a trace for you over the weekend Link to comment Share on other sites More sharing options...
Wez Posted January 25, 2008 Author Share Posted January 25, 2008 Just been offered a brand new HP iPaq HX4700 for £50. Need to find out if I can get a serial port working on it. Link to comment Share on other sites More sharing options...
Wez Posted January 25, 2008 Author Share Posted January 25, 2008 Looks like the HX4700 has a serial port and I can either make or buy a cable Where is the best place to start with development on these devices, MSDN recommends Visual Studio which includes emulator images etc. Link to comment Share on other sites More sharing options...
Wez Posted January 25, 2008 Author Share Posted January 25, 2008 I now have a HP HX4700 PDA, I have setup the development suite and emulator, I built and tested a simple hello progam which is working on the PDA and emulator Link to comment Share on other sites More sharing options...
MrRalphMan Posted January 26, 2008 Share Posted January 26, 2008 Nice one... what dev suite are you using? Link to comment Share on other sites More sharing options...
