shaft Posted January 20, 2008 Share Posted January 20, 2008 i have a jap 94 tt with a 5speed box, yes i kno but it was n/a in jap land. my question is this: does anyone know if the 5speed and 6 speed clutches are interchangable? i.e. can i just order an oem toyota 6speed item and will it deffinately fit on my 5speed imput shaft? thanks in advance new supra owner Quote Link to comment Share on other sites More sharing options...
bignum Posted January 20, 2008 Share Posted January 20, 2008 They are different as far as i know. Quote Link to comment Share on other sites More sharing options...
merckx Posted January 21, 2008 Share Posted January 21, 2008 They are different as far as i know. The EPC does confirm that they aren't the same. Quote Link to comment Share on other sites More sharing options...
JODY T Posted January 21, 2008 Share Posted January 21, 2008 as above, they wont fit each other either.. Ive found that a new OEM 5 Speed handles the standard TT power okay... but it might be better in the long run to get an aftermarket clutch designed to hold more power.. if you have the money get a OS Giken one, the pedal feel is brilliant, or if moneys abit tight get a RPS Clutch.. Although the pedal gets heavy, and to be honest i dont like em purley for that reason.. Quote Link to comment Share on other sites More sharing options...
shaft Posted January 24, 2008 Author Share Posted January 24, 2008 after reading every clutch thread on the forum ive decided to go with an rps street max. thanks guys Quote Link to comment Share on other sites More sharing options...
miko_supra Posted January 24, 2008 Share Posted January 24, 2008 after reading every clutch thread on the forum ive decided to go with an rps street max. thanks guys i have this. its a very nice clutch to use Quote Link to comment Share on other sites More sharing options...
dini_the_owl Posted January 24, 2008 Share Posted January 24, 2008 i would have said rps as i tried many in mine,aprox 6 types i think and rps was best,i did use the stock 5spd at first ok at stock psi. at bpu it fell to its knees and i burnt out the clutch and flywheel jobs a badun. Quote Link to comment Share on other sites More sharing options...
Nic Posted January 24, 2008 Share Posted January 24, 2008 TRD do replacement clutch discs and clutch covers for the 5spd, I don't know what power they are rated at, but they will hold more than stock. If you'd like details/prices drop me a pm. Quote Link to comment Share on other sites More sharing options...
shaft Posted January 24, 2008 Author Share Posted January 24, 2008 my clutch has roasted the flywheel id say, do you HAVE to replace the flywheel aswel as the clutch then ? Ive seen fellas rubbing the flywheel with sandpaper when they have heat spots and are fitting a new clutch and they seem fine after, what do yee think? Quote Link to comment Share on other sites More sharing options...
shaft Posted July 6, 2008 Author Share Posted July 6, 2008 fly was ROASTED when i took it out. got a machining company to skim it. job done. rps stage 4 clutch is good. hard to slip it, its kinda on or off Quote Link to comment Share on other sites More sharing options...
