Hello
Guest castensson
Guest castensson
Hello. New member from sweden.
my car.
im looking for OEM side skirts and OEM rear spats, but i cant poste in the wanted section why?
sorry for bad eng.
Guest castensson
Some specc.
Engine
*Turbo Choice: T67 P trim Polish Compressor Housing
*Dual Ball Bearing Center Cartridge
*A/R Housing choice: .68
*Boost Logic Ceramic Heat Coated SUS321 Tig Welded Tubular Header
*HKS 50mm SS Wastegate
*4” Stainless Steel 304 Downpipe
*4” Stainless Steel 304 Midpipe
*4” Aluminum Intake Pipe with Anti-Heat Coating
*2 1/2" Aluminum Intercooler Pipe with Anti-Heat Coating
*Braided Oil feed and Return Kit with Aeroquip fittings and Lines
*4" K&N Filter
*K&N Breathers (x2)
*High Quality Silicone Connecters
*Greddy profec-b spec-2 BC
*Greddy BCC
*Greddy Intercooler
*Greddy Type R blow off valve
*Greddy Blow Off Valve Flange - Aluminum
*Boost Logic MKIV Upgraded Fuel System
*Greddy 6*850cc Injectors
*Boost Logic Fuel Rail
*Dual GSS341 Walbro Pumps w/ Install Kits
*Aeroquip AN fittings and Braided lines
*Aeromotive -10AN Fuel Filter
*Aeromotive -10AN Fuel Pressure Regulator
*0-100PSI Fuel Pressure Gauge
*6 Injector Pig-tails
*High Quality Relays and Power Lines
*6 NGK Bcpr7es (3330)
*TRD Oilfilter
Transmission/Drivetrain
*Stock Getrag 6-speed manual transmission
*RPS stage III
*RPS flywheel
engine
*Mapecu II 1.5 bar
Chassi
*Greddy fjäderbensstag fram
*Cusco fjäderbensstag bak
*Eibach pro kit
Rims and tires
*19" HP Design Chrome Evo
*19x8,5 Front
*19x9,5 Rear
*275/30/19 Rear
*245/35/19 Front
Brakes
*330mm 4kolvsok Front
*320mm 2kolvsok Rear
*Hawk Brakepads Front
*Hawk Brakepads Rear
interior
*Innovate Bredband 52mm
*Greddy A-Stolpe 2*60mm
*Greddy EGT Peak and hold 60mm
*Greddy Boost Peak and hold 60mm
Styling
*98ans Front
*98ans Frontblinkers
*98ans Sidoblinkers
*98ans rear light
*RMM carbon front
*RMM carbon wing
