BOV and induction
lee_kelsey
Guys,
I currently have a blitz induction kit on my beast, but have recently read a review which claims they are the worst for filtering dust and any other fine particles of crap!
Was interested to hear any experiences recommendations you have had with these kits, as I am now looking at changing mine.
Also, I have the standard j-spec BOV and am looking to upgrade this to, any recommendations here to, would be appreciated.
Rgds
Lee
Rgds
Lee
Changing your BOV isn't really an upgrade. The stock item works perfectly well on stock or BPU cars.
Gavin,
I assumed that a larger BOV would provide a larger exit for excess gases, therefore expelling them more quickly, resulting in a 'slight' performance increase?
I also don't have a stock car, I just havent got round to doing this bit yet.
rgds
Originally posted by Mark Ayling
...each to their own!
Isn't the HKS SQV the latest favourite? I think its adjustable as well.
I'm sure someone who knows what they're talking about will pop in any minute....! :conf:
I've checked those out on Justins site (£245!), so I could get one sunday, providing he has them in stock! :)
Gavin,
rgds
I haven't read anything too suggest this.
Guest Martin F
Gavin,
rgds
I don't think that's quite the case.
I could be wrong, but i think the only advantage to an upgraded BOV is that it can work under higher pressures where the stock one can eventually fail.
Oh and of course the noise, if you like that sort of thing. :D
Not that I know anything about this on a technical level, but this is from the RaceLogic site:
When the boost is increased on a modified turbo car, the standard dump valve usually cannot cope with the extra air it has to release when the throttle is shut. This can lead to permanent damage to the turbo as the air is forced back through the inlet blades. BLITZ performance piston-type dump valves are designed for modified engines up to 750 BHP.
I'd be interested to know what they do do though, if anything!
I have......!
http://www.wave.co.nz/~hksnz/blowoff.html
The majority of blow off valves will not show a significant increase in useable power to any turbocharged engine. The HKS SQV will increase power. The reasoning is very simple, most blow off valves are of the kind which blow OPEN under pressure, and at high boost levels these begin to open, which bleeds off boost, forcing the turbocharger to work harder to reach the required boost target.
The HKS SQV blows CLOSED and can only be opened by a manifold vacuum signal.This allows a much faster turbo spool rate and decreases turbo compressor output temperatures.
The HKS SQV also utilises a dual valve arrangement which allows rapid valve response when only the smaller valve is required and the ability to release large volumes of boost is easily controlled by a larger secondary valve.
All HKS SQV kits are type specific and are complete with full instructions and all components required for installation.
Guest Martin F
They are supposed to prevent the compressor blades from stalling as you let off the throttle. The idea being that as you go from WOT to totally closed throttle that the compressed charge has nowhere to go and as the pressure builds up in the induction piping the compressor blades will slow down and this will increase the time it takes for the compressor to spool up again once you get back on the throttle.
By putting a BOV in the induction piping you allow the pressure to be bled off(perhaps not the best term), either to atmosphere or to before the turbo's like in the stock system.
Guest Martin F
Well as far as i know it's only aesthetics, i.e. it sounds nice, but i could be wrong there.
Remember vent to atmosphere BOV's can cause problems on UK\US spec cars, but don't tend to on Jap spec cars due to the MAF or lack of.
I have......!
Hmmm... I would agree that there would be a performance increase in replacing any BOV that leaks under high boost pressure with this design of closed BOV. If however your BOV is not leaking where will the improvement be coming from?
In addition, for this company to state that "most blow off valves are of the kind which blow OPEN under pressure, and at high boost levels these begin to open" is a bit misleading too say the least.
