JNk10 Posted January 19, 2008 Share Posted January 19, 2008 My supra got broken into and the heater wires got cut. Toyota connected them back up but didnt connect them properly. I thought i would have a look myself so followed the wires down to the passenger foot well where they clip into another block. I diconnected the block, put power thru a couple of wires to see if they were connected to the correct bloke at the other end. For some reason, the car will not start now. I didnt cut any wires and connected the block back up. When i turn the ignition on, all the dash lights come on, but when trying to start the car, nothing happens. All I can hear though is the ABS relay clicking. Is this normal or have I blown something? Would this stop the engine from starting? Any help or suggestions would be much appreciated Quote Link to comment Share on other sites More sharing options...
SimonB Posted January 19, 2008 Share Posted January 19, 2008 Sounds like you have a flat battery. The clicking will be the starter motor solenoid engaging and disengaging from the current draw from trying to turn the starter. Try charging it or another known good one. Quote Link to comment Share on other sites More sharing options...
JNk10 Posted January 19, 2008 Author Share Posted January 19, 2008 After looking at it some more, it seems like it may be the immobiliser. Where is the immobilser located so that I can rip it out? Cheers Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted January 19, 2008 Share Posted January 19, 2008 under drivers seat sometimes, if you can the clicking of the starter, it wont be an immobiliser problem! Quote Link to comment Share on other sites More sharing options...
JNk10 Posted January 21, 2008 Author Share Posted January 21, 2008 I really dont know what the problem is. I had a mate come to look at the car last nite and he said every fuse etc is getting power to it. I dont know enough about cars to know how to fix it, but any suggestions of what it could be would be very helpful. The clicking I hear when trying to start the car is the abs relay, not the starter. Does it sound like ive blown the ecu or anything else? All the other electrics work in the car. Quote Link to comment Share on other sites More sharing options...
