Ian R Posted January 12, 2005 Share Posted January 12, 2005 Have searched the forum on tyre sizes but cant find what i'm looking for I have 18 inch wheels and want to put 265 on the rear what is the best wall size for the rear and the best front combination to go with them ? Quote Link to comment Share on other sites More sharing options...
Alex Posted January 12, 2005 Share Posted January 12, 2005 Rear profile on a 265 18 is a 35 (265/35/ZR18) Front should be a 235/40/ZR18 Quote Link to comment Share on other sites More sharing options...
supRo Posted January 12, 2005 Share Posted January 12, 2005 Have searched the forum on tyre sizes but cant find what i'm looking for I have 18 inch wheels and want to put 265 on the rear what is the best wall size for the rear and the best front combination to go with them ? I have 235/40/18 on front and 265/35/18 on the back. I've seen a few supras with that setup but I'm no expert. I'm sure someone else will have more info...Whilst we at this subject, what's the best tyre pressure for the front and back for this sort of setup? Cheers Quote Link to comment Share on other sites More sharing options...
supRo Posted January 12, 2005 Share Posted January 12, 2005 Rear profile on a 265 18 is a 35 (265/35/ZR18) Front should be a 235/40/ZR18 You just beat me with your posting by a few mins - wasn't there when I hit the reply button ;-) Quote Link to comment Share on other sites More sharing options...
Bill Prawn Posted January 12, 2005 Share Posted January 12, 2005 Or try this Quote Link to comment Share on other sites More sharing options...
chrisda Posted January 12, 2005 Share Posted January 12, 2005 Rear profile on a 265 18 is a 35 (265/35/ZR18) Front should be a 235/40/ZR18 Whick " should it be on the wheels on the back when I should fit 265? So it getting a good grip also? CHris Quote Link to comment Share on other sites More sharing options...
Tom S Posted January 12, 2005 Share Posted January 12, 2005 yo matey, mine is the same sizes, just bought new front ones........ glad aint got to do that again for a while :eek2: Quote Link to comment Share on other sites More sharing options...
merckx Posted January 12, 2005 Share Posted January 12, 2005 Whick " should it be on the wheels on the back when I should fit 265? So it getting a good grip also? CHris Not sure if chrisda wanted to know the wheel width aswell "9,5 or 10" It was in the title . Quote Link to comment Share on other sites More sharing options...
snake Posted January 12, 2005 Share Posted January 12, 2005 I have volks racing alloys with 285/35/18 on the rear and 265/35/18 on the front if thats any help Quote Link to comment Share on other sites More sharing options...
chrisda Posted January 12, 2005 Share Posted January 12, 2005 Not sure if chrisda wanted to know the wheel width aswell "9,5 or 10" It was in the title . I have found 4 wonderful wheels but they are just in 9,5" Can I fit 265 on a 9,5 wheel. Is it any good? Regards Chris Quote Link to comment Share on other sites More sharing options...
supRo Posted January 12, 2005 Share Posted January 12, 2005 I have volks racing alloys with 285/35/18 on the rear and 265/35/18 on the front if thats any help Damn you've got some fat rubber! What's your Supe lowered by? Do the tyres touch the arches at all? How's the handling like? Cheers Quote Link to comment Share on other sites More sharing options...
Alex Posted January 12, 2005 Share Posted January 12, 2005 The front and rear wheels should NOT be the same widths. Nor should the tyres. As an aside, fat rubber makes you more prone to aquaplaning. Quote Link to comment Share on other sites More sharing options...
merckx Posted January 12, 2005 Share Posted January 12, 2005 The front and rear wheels should NOT be the same widths. Nor should the tyres. . Mine are , the car came like this 255/35 18 Quote Link to comment Share on other sites More sharing options...
Lez Posted January 13, 2005 Share Posted January 13, 2005 The original stock wheels were 16s 8JJ 225/50/16 and 9JJ 245/45/16 with rolling diameter 631mm & 627mm respectively However, from Aug94 the optional stock wheels were 17s 8JJ 235/45/17 and 9.5JJ 255/40/17 making the rolling diameters 643mm & 636mm respectively. Therefore best size for 18s are 235/40/18 = 645mm and 255/35/18 = 636mm However the recommended deviation is 2.5% so the max oversize from the 17s is; Front 245/45/17 = 652mm +1.4% 245/40/18 = 653mm +1.56% 245/35/19 = 654mm +1.71% Rear 275/40/17 = 652mm +2.52% 275/35/18 = 650mm +2.2% 275/30/19 = 648mm +1.89% Quote Link to comment Share on other sites More sharing options...
lightwave Posted January 13, 2005 Share Posted January 13, 2005 This is a crazy thread. Nobody's answering people's questions really. Lez: The wheels coming my way are 18x9 front and 18x10.5 rear. I'm getting the aforementioned 245/40/18 front and 275/35/18 rear. I assume that means they'll be ok? Quote Link to comment Share on other sites More sharing options...
Lez Posted January 13, 2005 Share Posted January 13, 2005 This is a crazy thread. Nobody's answering people's questions really. Lez: The wheels coming my way are 18x9 front and 18x10.5 rear. I'm getting the aforementioned 245/40/18 front and 275/35/18 rear. I assume that means they'll be ok? Yes the tyre size looks good for the rolling diameter, but you might be better with 255/35/18 =636mm and 295/30/18 = 634mm to fit the wheel rim width better. Also check that the wheels are 50mm offset (ET50) and that they will clear the brake callipers and suspension. With this offset the backspace from the hub to the inboard rim will be 7" for the 9s and 8" for the 10.5s Maybe someone with 9s & 10.5s fitted could comment. Quote Link to comment Share on other sites More sharing options...
Guest Tom80 Posted January 14, 2005 Share Posted January 14, 2005 Rear profile on a 265 18 is a 35 (265/35/ZR18) Front should be a 235/40/ZR18 I've got the same dimensions on mine. This size was chosen by a professionnal tire shop in Japan in order to be accepted at the very strict annual technical check. Quote Link to comment Share on other sites More sharing options...
