hand break light on under breaking
Andrew_sup
It'll be the brake fluid, common problem with Supras
The level of fluid in the master cylinder, needs only to be slightly below full for the dash light to illuminate under braking. I think the problem can be exacerbated if you have big brakes and the JDM master cylinder as the fluid level will drop more rapidly.
