Chris Wilson Posted January 16, 2008 Share Posted January 16, 2008 May be of general interest, I only just found this, a power point display of setting up an ecu http://www.gatesgarth.com/motec.ppt Link to comment Share on other sites More sharing options...
Pete Posted January 16, 2008 Share Posted January 16, 2008 Fixed link. http://www.gatesgarth.com/motec.ppt I need to be much less tired to concentrate on that. Looks very interesting though. Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 17, 2008 Author Share Posted January 17, 2008 I have had this before, and don't understand it. I mistyped and put gatsgarth , then saw my error, and edited it to gatesgarth, which is what I now see in MY post, yet I click on it, and Firefox won't connect as it's trying to reach gatsgarth still? What gives...? And thanks for fixing it Pete, but see below: http://www.gatesgarth.com/clip.jpg Link to comment Share on other sites More sharing options...
JustGav Posted January 17, 2008 Share Posted January 17, 2008 Cheers for that Chris, some nice reading in there. Link to comment Share on other sites More sharing options...
Ryan.G Posted January 17, 2008 Share Posted January 17, 2008 I recognise that presentation One of the first sheets you go through at MoTeC to help touch the basics. Ryan Link to comment Share on other sites More sharing options...
JustGav Posted January 17, 2008 Share Posted January 17, 2008 Chris, have you tried reloading the page with a shift-f5. Normally ISP's use proxy servers which keep a copy of the page, and you might find it is sending you the stored copy still. Link to comment Share on other sites More sharing options...
b_have Posted January 17, 2008 Share Posted January 17, 2008 Good presentation Bit confused as to the Map sensor positioning : "MAP sensor should be connected to the Intake Manifold below the throttle blade" Just deciding where to locate my map and AIT sensors in the new plenum. Any pointers here? Link to comment Share on other sites More sharing options...
Pete Posted January 17, 2008 Share Posted January 17, 2008 When you click edit you need to edit the location in two places. You hadn't changed this bit: [ URL = "http://www.gatesgarth.com/motec.ppt" ] Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 17, 2008 Author Share Posted January 17, 2008 When you click edit you need to edit the location in two places. You hadn't changed this bit: [ URL = "http://www.gatesgarth.com/motec.ppt" ] Ah, I see, thanks Pete, I'll try harder next time, Sir Link to comment Share on other sites More sharing options...
Pete Posted January 17, 2008 Share Posted January 17, 2008 Ah, I see, thanks Pete, I'll try harder next time, Sir I should hope so too! Can we have a colour screenshot next time too? Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 17, 2008 Author Share Posted January 17, 2008 And there was I trying to reduce the file size to be helpful. I will boil my head later. Link to comment Share on other sites More sharing options...
