supraspeed Posted January 13, 2008 Share Posted January 13, 2008 This might sound like a stupid question...and probably is.... but when people talk about a turbo being 400bhp or 600bhp etc.. is this talking about what the turbo produces or what the car will produce when its fitted or what the turbo's capable of etc...??? Link to comment Share on other sites More sharing options...
tooquicktostop Posted January 13, 2008 Share Posted January 13, 2008 It is a reference to the potential of the turbo Link to comment Share on other sites More sharing options...
AndyT Posted January 13, 2008 Share Posted January 13, 2008 Each turbo has a rating with supporting mods of course. Stock TT = approx 320 bhp. Go single = whatever you want, 1000 bhp anyone. There are loads of turbos and loads of people here have fitted various types. Type in GT4088, T61, T78, etc in search and reap the benefits. Link to comment Share on other sites More sharing options...
supraspeed Posted January 13, 2008 Author Share Posted January 13, 2008 i would like to know what my turbo is but theres so much stuff above & between it that i can't make out anything, plus its got surface rust or something on the actual turbo so i can't make out any names or ref codes...also doesn't help having heat plates everywhere lol... Link to comment Share on other sites More sharing options...
AndyT Posted January 13, 2008 Share Posted January 13, 2008 i would like to know what my turbo is but theres so much stuff above & between it that i can't make out anything, plus its got surface rust or something on the actual turbo so i can't make out any names or ref codes...also doesn't help having heat plates everywhere lol... The type etc. should be cast into the forging mate. Everyone likes to advertise, however that means you need to get some wire wool on it to discover what you've got. From that - here or Google. Link to comment Share on other sites More sharing options...
tooquicktostop Posted January 13, 2008 Share Posted January 13, 2008 Did you buy it with any history ?? Turbo does not look too big, could be a T70 perhaps, if you can get it to a tuner on here they will tell you, worth getting the set up checked over as its new to you anyway Link to comment Share on other sites More sharing options...
supraspeed Posted January 13, 2008 Author Share Posted January 13, 2008 The things that i need to do with this cars proper piling up, find and fix traction control, convert km-mph, fix interior lights, fix handbrake, get car dyno'd, find out what map setting its running on, fit working seatbelts, get aircon gassed, get new spoiler sprayed and fitted, get new headlight, buy new tires to fit new wheels, fit wheels, find out why all aftermarket gauges shut off independantly of each other in 3 days, change exhaust system, ...........use wire wool to uncover turbo make.....tomorrow...find out where my moneys going...... Link to comment Share on other sites More sharing options...
tooquicktostop Posted January 13, 2008 Share Posted January 13, 2008 The things that i need to do with this cars proper piling up, find and fix traction control, convert km-mph, fix interior lights, fix handbrake, get car dyno'd, find out what map setting its running on, fit working seatbelts, get aircon gassed, get new spoiler sprayed and fitted, get new headlight, buy new tires to fit new wheels, fit wheels, find out why all aftermarket gauges shut off independantly of each other in 3 days, change exhaust system, ...........use wire wool to uncover turbo make.....tomorrow...find out where my moneys going...... Hmmm, will not be such a cheap car then when finished What ECU is the car running, you stated 400-450 BHP in your sig how do you know ?? Link to comment Share on other sites More sharing options...
supraspeed Posted January 13, 2008 Author Share Posted January 13, 2008 FCon V (V-5 i presume) i was told buy the seller- gave me a load about loosing the dyno readout and its on a certain amount of boost etc... i gave my dad a quick run on the motorway against his evo fq400 and i was a bit quicker so i'd imagine its around those figures anyway- i'l be well pissed if it turns out not to be though..... Link to comment Share on other sites More sharing options...
tooquicktostop Posted January 13, 2008 Share Posted January 13, 2008 Where was it brought from mate?? I would get it in for a full inspection of the set up before you worry about getting it dynoed and power figures, have you seen the FCON??, there are not many tuners who map these unfortunatly It is worth getting the cars fuelling checked and ensure everything is running ok and in safe tollerances before you get too carried away with further mods HKS Pistons seems like the sort of thing that may not exist, cant remember the last NA engine I saw on here that had been treated to those Link to comment Share on other sites More sharing options...
bromy Posted January 13, 2008 Share Posted January 13, 2008 FCon V (V-5 i presume) Have a dig around the passenger footwell under the carpet for the gold coloured FCon box... it may well be under the black plastic ECU protective cover (2x10mm bolts to undo) as mentioned though get the fueling checked as from the interior shot I cant see a AFR gauge Link to comment Share on other sites More sharing options...
supraspeed Posted January 13, 2008 Author Share Posted January 13, 2008 Have a dig around the passenger footwell under the carpet for the gold coloured FCon box... it may well be under the black plastic ECU protective cover (2x10mm bolts to undo) as mentioned though get the fueling checked as from the interior shot I cant see a AFR gauge yeah, its under the passanger floormat, not very secretive. i got the car off ebay from some trader who got it from japan but only told me he had no idea of what was going on under the bonnet only after the gearbox exploded! cheeky c*nt!!! that was a month later but like a sucker i didn't get a warrenty or n e thing so i was screwed really. he's recently stopped trading.....i wonder why, tw*t Link to comment Share on other sites More sharing options...
