jamesmark Posted January 13, 2008 Share Posted January 13, 2008 I have noticed a few times that when going from D to R that the car does not want to move, it just sits in neutral then after a 1-2 seconds reverse engages and were off, but it then comes out of gear 1-2 seconds later it goes back into reverse. It done it 3 times in 20m that I was reversing. It also happens when selecting D it will pause for a moment then I have drive. Both scenario's it is as if I have a box full of neutrals but only for 1-2 seconds before the autobox engages gear. It only happens when I have been stopped as driving, overtaking etc is all fine with no issues. I am still to do error codes, but I have no had any warning lights etc as yet. Oil was filled up in the box on last service. Link to comment Share on other sites More sharing options...
flukey-lukey Posted January 13, 2008 Share Posted January 13, 2008 replying to PM... Link to comment Share on other sites More sharing options...
flukey-lukey Posted January 13, 2008 Share Posted January 13, 2008 Removal and installation guide.. I'm no mechanic and managed to follow this step by step quite easily Ric also helped...a bit Link to comment Share on other sites More sharing options...
Ric Posted January 13, 2008 Share Posted January 13, 2008 a bit fu*k off the box almost fell on my head while i was taking the bolts out lol Link to comment Share on other sites More sharing options...
flukey-lukey Posted January 13, 2008 Share Posted January 13, 2008 I only said it because I could see you viewing the thread Don't cry Sorry Mark thats the wrong guide... the one I used was much more detailed and had pictures... I'll look for it Link to comment Share on other sites More sharing options...
VIL Posted January 14, 2008 Share Posted January 14, 2008 james - I think its a box sensor causing the problem - dont know whick one though (I have it, but only happens on the odd occasion). As a quick fix, pull the stick into L and drive off manually, once into D it should be OK. If your looking to reverse, do the same, pull the stick into L (wait to feel it engage) and push it back up to R and you should be OK. I have posted the issue before as others have it but to my knowledge no one yet has cured the problem? Hope this helps. Link to comment Share on other sites More sharing options...
jamesmark Posted January 14, 2008 Author Share Posted January 14, 2008 Cheers Vil. Will give that a bash. Funny you should say that as it is fine when I feel another gear engage. Link to comment Share on other sites More sharing options...
flukey-lukey Posted January 14, 2008 Share Posted January 14, 2008 If you want to try and change certain sensors on the box I still have my old box with the sensors on. It was my TC that gave up so the sensors should still be ok... they're a bit of a pig to get to while the box is still on the car though Link to comment Share on other sites More sharing options...
jamesmark Posted January 16, 2008 Author Share Posted January 16, 2008 james - I think its a box sensor causing the problem - dont know whick one though (I have it, but only happens on the odd occasion). As a quick fix, pull the stick into L and drive off manually, once into D it should be OK. If your looking to reverse, do the same, pull the stick into L (wait to feel it engage) and push it back up to R and you should be OK. I have posted the issue before as others have it but to my knowledge no one yet has cured the problem? Hope this helps. Cheers Vil. Will give that a bash. Funny you should say that as it is fine when I feel another gear engage. Whilst reversing it still slips in and out of gear and I tried what Vil mentioned too but still does it. Link to comment Share on other sites More sharing options...
