gaz1 Posted January 13, 2008 Share Posted January 13, 2008 ok i still after many years am not sure what they are, where they go, and are they included in turbo kits:rolleyes: anyone have an idea, just trying to work out if i have one for my new turbo system, and if i need one Link to comment Share on other sites More sharing options...
JamieP Posted January 13, 2008 Share Posted January 13, 2008 Small peice of pipe that conects to the wastegate, you will have one in your new kit id imagine:) Link to comment Share on other sites More sharing options...
supradibbs Posted January 13, 2008 Share Posted January 13, 2008 ok i still after many years am not sure what they are, where they go, and are they included in turbo kits:rolleyes: anyone have an idea, just trying to work out if i have one for my new turbo system, and if i need one Included with the BL kit mate evacuates air outta the wastegate whilst on boost hope that makes sense not too good at explaining things Link to comment Share on other sites More sharing options...
Pig Posted January 13, 2008 Share Posted January 13, 2008 Your new kit will come with one. Waaaay too slow Link to comment Share on other sites More sharing options...
Daston Posted January 13, 2008 Share Posted January 13, 2008 Same as what others have said really. However some people conect them to the exahust so they dont make too much noise and scare old ladies Link to comment Share on other sites More sharing options...
gaz1 Posted January 13, 2008 Author Share Posted January 13, 2008 i had it in my head that it is a hard pipe that slides into the downpipe, or am i just being silly:rolleyes: Link to comment Share on other sites More sharing options...
JamieP Posted January 13, 2008 Share Posted January 13, 2008 i had it in my head that it is a hard pipe that slides into the downpipe, or am i just being silly:rolleyes: It vents from the wastegate while on boost, you can have it conected back into the downpipe if you want to keep the noise down for track days etc, i think some of the HKS hits come like this. Link to comment Share on other sites More sharing options...
gaz1 Posted January 13, 2008 Author Share Posted January 13, 2008 It vents from the wastegate while on boost, you can have it conected back into the downpipe if you want to keep the noise down for track days etc, i think some of the HKS hits come like this. ahhh thats where i had heard that;) Link to comment Share on other sites More sharing options...
kieren1234 Posted January 13, 2008 Share Posted January 13, 2008 i had it in my head that it is a hard pipe that slides into the downpipe, or am i just being silly:rolleyes: No your not being silly. Some people do recirculate the screamer pipe back into the exhaust/downpipe. It is basibally a really thin exhaust that carries exhaust gasses away from the opening of the wastegate when it is open. Like this: http://cgi.ebay.co.uk/turbocharger-turbo-40-mm-wastegate-with-dump-tube_W0QQitemZ110214009150QQihZ001QQcategoryZ72205QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Link to comment Share on other sites More sharing options...
miko_supra Posted January 13, 2008 Share Posted January 13, 2008 what are mot places like on emissions with this? Link to comment Share on other sites More sharing options...
TLicense Posted January 13, 2008 Share Posted January 13, 2008 In laymans terms, when the engine is offboost, or the turbo is spooling, then the wastegate will be shut and the exhaust gas will be flowing through the turbo and into the exhaust. As the turbo get's up to speed, and you achieve enough boost to open the wastegate, then the exhaust flow no-longer flows through the turbo (or rather the amount of exhaust flow through the turbo is reduced by bleeding some of it off through the wastegate). As the exhaust gas going through the wastegate needs to go somewhere, there's one of 2 things you can do. 1. Have a screamer pipe. It's a pipe attached to the wastegate on one end, and usually open ended on the other, which just kinda points the exhaust gas going through the wastegate somewhere under the engine where its' less likely to melt something. As the name suggests, a screamer pipe is going to be LOUD, as you've basically not got any silencer, or any real exhaust at all to speak of. Imagine running your car with no manifold. It's nearly as loud as that. 2. The other option is to re-route the exhaust gas coming out of the wastegate back into the exhaust. This up-side of this is it's less likely to cause melting problems, but it's significantly more difficult to set-up. It's also quieter, which some see as a good thing, and some see as bad. Link to comment Share on other sites More sharing options...
TLicense Posted January 13, 2008 Share Posted January 13, 2008 what are mot places like on emissions with this? They won't be able to put the engine under enough load to open the wastegate, so it shouldn't ever be a problem. Link to comment Share on other sites More sharing options...
miko_supra Posted January 13, 2008 Share Posted January 13, 2008 so when the waste gate opens is that when you hear that really loud rushing/sucking (whoosh) sound? or is it literally like taking half the exhaust system off all of a sudden? Link to comment Share on other sites More sharing options...
TLicense Posted January 13, 2008 Share Posted January 13, 2008 The whoosh sound will be a combination of the turbo's sucking air in through the induction and the wastegate opening, which is as you describe like taking half the exhaust off. Link to comment Share on other sites More sharing options...
Gazboy Posted January 13, 2008 Share Posted January 13, 2008 The loudest screamer I ever heard was a RUF 911, watching that thing go past at 200mph sounded like a jet fighter hooning along a runway. Link to comment Share on other sites More sharing options...
tooquicktostop Posted January 13, 2008 Share Posted January 13, 2008 I have a screamer pipe fitted to my HKS system and it vents out to the atmosphere and not down the exhaust, great sound when on full chat, also makes some interesting marks on the floor of a rolling road ! Link to comment Share on other sites More sharing options...
Mike B Posted January 13, 2008 Share Posted January 13, 2008 I couldn't live with mine; had to re-plumb Link to comment Share on other sites More sharing options...
Ryan.G Posted January 13, 2008 Share Posted January 13, 2008 I couldn't live with mine; had to re-plumb Me Too Link to comment Share on other sites More sharing options...
Muffleman Posted January 13, 2008 Share Posted January 13, 2008 It prevents me hitting the track, but otherwise I don't mind it - don't drive it enough for it to get on my nerves ! Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 13, 2008 Share Posted January 13, 2008 I couldn't live with mine; had to re-plumb And very neatly, too, the exhaust is one of the best fits for such a monster pipe size I have seen. Link to comment Share on other sites More sharing options...
mikeyb10supra Posted January 13, 2008 Share Posted January 13, 2008 I have a cast manifold kit and prototype arnout made including a flexi section that plumbs the exit for the gate back into the downpipe....looks like a perfect fit as well, very well made Link to comment Share on other sites More sharing options...
TurboBrett Posted January 13, 2008 Share Posted January 13, 2008 if you want the quietness of the re-plumbed 'screemer' AND the loudness of the open to air screem you could always use one (or a couple) of them exhaust valve things;) and have it(them) on a switch Clicky EDIT: lol i didnt mean to find one relating to the supra either this is more what i was thinking off Clicky Link to comment Share on other sites More sharing options...
Supra Pilot Posted January 13, 2008 Share Posted January 13, 2008 The Waste gate exhaust when vented to atmosphere is called a 'screamer pipe'. (hence the name) When it is plumbed back into the Exhaust system it is not a screamer pipe! Link to comment Share on other sites More sharing options...
GazzaGSi Posted January 13, 2008 Share Posted January 13, 2008 Mine was fitted with a screamer. I luv'd it! Sounded awesome (if you like that sort of thing) Need to be carful it doesnt foul on the stearing nuckle though. Link to comment Share on other sites More sharing options...
Wez Posted January 13, 2008 Share Posted January 13, 2008 I couldn't live with mine; had to re-plumb Mine should be done next month along with some mid pipe silencers Link to comment Share on other sites More sharing options...
