derestriction how !!!! help please
thesword22
hi guys
i need to derestrict my supra has anyone got any guides for this please.
any idea were i would get the parts as well please
any help appreiciated guys.
i dont like being stuck 111mph :blink:
YOu need a sld (www.thor-racing.co.uk they might still make them but doubt it.
Or an HKS SLD.
There shoudl be fitting guides somewhere on here in the tech section or by visiting www.mkiv.com
  • 4 months later...
Guest twinturboted
i have jap instructions but dont know if i need to wire a-ecu b-ecu c-ecu or a trc a etcs or b-etcs
a and b ecu look similar plugs to mine but if its a do i wite a-etcsor a-trc
its a t6 hks sld and have no idea what to do its a 1994/5 twin turbo auto box supra any help please.
  • 3 weeks later...
Guest twinturboted
the engish manual was a big help thanks guys but when you look at the single plug etcs it upside down the plug has 3 locking points one end and two the other dont use the 3 humps as a guide to the shape of the plug as when wired that way the slip dif off light and the overdrive light flash as its wired wrong also one of the wires goes to a blank pin which you will see is wrong.
got there in the end cheers guys top site this.:D
