kieren1234 Posted January 12, 2008 Share Posted January 12, 2008 Problem: I have a problem with the e-manage blue. When the e-manage is plugged into the car, i have tried the connecting it to the laptop and opening the e-manage software (already installed) It then stats in offline mode and will not go online?? Does anyone have any ideas why and what am i doing wrong?? When installing the CD it asks for a verification number (i think that was what it was called) and i dont have one so just put a random number and it seemed to install ok......... Any help is greatly appreciated. The whole purpose of doing this is to get a base map onto the e-manage. Thanks. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 12, 2008 Share Posted January 12, 2008 The software install thing is normal, as for connection, i have to ask the obvious first, you have got the ignition switched on, and the light is lit on the emanage unit? Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted January 12, 2008 Author Share Posted January 12, 2008 Thats right mate. The light comes on and when you plug the USB into the e-manage, the connection lights begins to flash. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 12, 2008 Share Posted January 12, 2008 You may well have to specify a serial port on your laptop for it to connect, other than that maybe there is a problem with the cable itself, is it genuine or clone? Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted January 12, 2008 Author Share Posted January 12, 2008 Thanks, we have put the USB to port 3, and also the e-manage to port 3 so cant be the problem. The cable and CD are genuine (i know the CD is and assume the usb is) Quote Link to comment Share on other sites More sharing options...
JustGav Posted January 12, 2008 Share Posted January 12, 2008 The emanage blue doesn't plug into the usb on the pc.. it is a serial cable. The usb-looking port on the blue isn't USB in function. How do you mean you have the emanage set to port 3? Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted January 12, 2008 Author Share Posted January 12, 2008 The emanage blue doesn't plug into the usb on the pc.. it is a serial cable. The usb-looking port on the blue isn't USB in function. How do you mean you have the emanage set to port 3? Well the cable i have is usb on each end, the big black part goes into the laptop and the other usb goes into the e-manage?? Definate usb ports. I have gone into the e-manage CD and loaded it up, then options, and select COM port 3. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 12, 2008 Share Posted January 12, 2008 Yes emanage blue does not connect via USB it definitely serial, the genuine cable is a kind of transparent which you can see the silver shielding through, sounds like its some sort of clone USB converter, the other possibility is that you have one of the fake emanages not made by Greddy:( Can you post a pic of the cable? Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted January 12, 2008 Author Share Posted January 12, 2008 Yes emanage blue does not connect via USB it definitely serial, the genuine cable is a kind of transparent which you can see the silver shielding through, sounds like its some sort of clone USB converter, the other possibility is that you have one of the fake emanages not made by Greddy:( Can you post a pic of the cable? Its definately a genuine e-manage mate, have the box with warranty etc. The pc cable has a usb on one end and another on the other end. It is a black cable so im assuming i have the wrong bable. Where can i get a genuine one from?? What is the sort of connector on the laptop end of the cable. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 12, 2008 Share Posted January 12, 2008 Thats very strange, when did you buy the unit and did it come with software and cable or did you get them separate? Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted January 12, 2008 Author Share Posted January 12, 2008 I bought the e-manage and support tool off a guy on here and it all came as one so unsure about the cable. Do you have a picture of a genuine cable as i would like to see what the connector is like at the laptop end (e-manage end is usb??) Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted January 12, 2008 Author Share Posted January 12, 2008 is this the sort of end my cable is meant to have?? http://www.mohdparts.com/emanage/usb_cable.jpg Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 12, 2008 Share Posted January 12, 2008 is this the sort of end my cable is meant to have?? http://www.mohdparts.com/emanage/usb_cable.jpg No thats just an A/B USB for connecting to the EO-1 the correct cable looks like this, http://www.mohdparts.com/emanage/support_tool_box_open.jpg Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted January 12, 2008 Author Share Posted January 12, 2008 So is it like the plug that is on a monitor that goes into the PC?? Like a 16pin plug?? Where can i get one of these from?? Desperately need one asap. Many thanks for all the help. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 12, 2008 Share Posted January 12, 2008 http://www.mohdparts.com Nic, or hunt around for a UK suppler, and no serial is not the same as monitor plug, just similar;) maybe someone near you could lend you one? Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted January 12, 2008 Author Share Posted January 12, 2008 Thanks mate. I will pm nic and see about getting the wire. Thanks so much for your help mate. It is greatly appreciated and solved a massive problem. Will update once i have the proper cable and report the results. Kind regards. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 13, 2008 Share Posted January 13, 2008 No problem, glad we got to the bottom of it in the end, hope you get it sorted, and keep us posted:) Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted January 13, 2008 Author Share Posted January 13, 2008 Cheers mate. Thanks for the help. I will get a new cable asap and hopefully sort the problem. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 6, 2008 Share Posted May 6, 2008 (edited) Further to this thread, same problem, doesnt communicate. Tried using the A/B cable but obviously that didnt work. I have the silver cable, the same as the one in the pic on this thread but the non serial end i.e. the USB end is the normal oblong shape, and there doesnt appear to be a place to connect to? Im guessing I have the wrong cable? Edited May 6, 2008 by Swampy442 (see edit history) Quote Link to comment Share on other sites More sharing options...
dini_the_owl Posted May 6, 2008 Share Posted May 6, 2008 (edited) can i just add the emanage blue can connect via usb,as stated it is serial when you buy the support tool from greddy but mine was connected via usb by a seller on ebay,usb type a on both ends but emanage end had some electronics in there to make it work as it will not connect with a standard type a to a usb lead. http://cgi.ebay.co.uk/Greddy-eManage-USB-Support-Tool-Cable_W0QQitemZ260231384689QQihZ016QQcategoryZ52640QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247 Edited May 6, 2008 by dini_the_owl (see edit history) Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 6, 2008 Share Posted May 6, 2008 can i just add the emanage blue can connect via usb,as stated it is serial when you buy the support tool from greddy but mine was connected via usb by a seller on ebay,usb type a on both ends but emanage end had some electronics in there to make it work as it will not connect with a standard type a to a usb lead. http://cgi.ebay.co.uk/Greddy-eManage-USB-Support-Tool-Cable_W0QQitemZ260231384689QQihZ016QQcategoryZ52640QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247 Already established earlier in this thread. Quote Link to comment Share on other sites More sharing options...
dini_the_owl Posted May 6, 2008 Share Posted May 6, 2008 Yes emanage blue does not connect via USB it definitely serial, the genuine cable is a kind of transparent which you can see the silver shielding through, sounds like its some sort of clone USB converter, the other possibility is that you have one of the fake emanages not made by Greddy:( Can you post a pic of the cable? Where? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 6, 2008 Share Posted May 6, 2008 Where? My post 13 shows a pic of the support serial cable, if thats what you mean. Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 8, 2008 Share Posted May 8, 2008 Further to this thread, same problem, doesnt communicate. Tried using the A/B cable but obviously that didnt work. I have the silver cable, the same as the one in the pic on this thread but the non serial end i.e. the USB end is the normal oblong shape, and there doesnt appear to be a place to connect to? Im guessing I have the wrong cable? The E-Manage blue has a normal rectangular USB port on its front panel. The E-Manage Ultimate has the Printer USB shaped port (looks like a monopoly house ) and uses a normal USB cable. -Ian Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted May 9, 2008 Author Share Posted May 9, 2008 To sort this i eneded up using the genuin greddy cable with the usb plugged into the e-manage, then an R232 (think thats what it is) cable plgged into the serial part of the greddy cable and the usb into the laptop. Works everytime. Quote Link to comment Share on other sites More sharing options...
