SupraRider Posted January 12, 2008 Share Posted January 12, 2008 Hi guys, have a question for you: I own a J-spec pre facelift NA, because the headlights are plastic, I found moisture and fogging on one of the front headlights. can anybody advise me on how to remove the headlights and clean it up? Quote Link to comment Share on other sites More sharing options...
JustGav Posted January 12, 2008 Share Posted January 12, 2008 You will need a 10mm socket with an extension bar. Take the airbox out just behind the drivers side one, take the battery out behind the passenger side one. There are three bolts holding them in. One on the top of the inside section of the headlight, just near the radiator. The other two are in a vertical pattern just inside the wing. Quote Link to comment Share on other sites More sharing options...
supra matt Posted January 12, 2008 Share Posted January 12, 2008 there is two 10 mm nuts on the back that hold it to the wing . then the 10mm bolt you can see on the top . Quote Link to comment Share on other sites More sharing options...
Dazzi Posted January 12, 2008 Share Posted January 12, 2008 had to get under the car to loosen the lower wing bolt - rusted up came off in the end tho. Quote Link to comment Share on other sites More sharing options...
