Headlight Bulbs
Stratty
Hi Guys
One of my headlights has gone and there is no-one local that stocks the bulbs.
My local Toyota dealer doesn't like imports so doesn't want to know either.
Is there anywhere on-line I can order them from?
It's the iddle bulb that has gone, 55w I think.
Cheers
Simon
I have had a quick look on fleabay for some bulds, does anyone know which ones would do the trick?
There seems to be lots on there but I really dont know what I am looking at.
Looking at the pics on fleabay, the fitting looks the same but some say H3 and others H4, I have no idea what this means?
HELP!!!
I have no headlights.... :(
If you have J-spec headlights you need
Low Beam 9005/HB3 (need to remove rib on connection to wiring loom)
High Beam 9005/HB3
Full explanation here:
http://mkivsupra.net/vbb/showpost.php?p=1570288&postcount=4
Thanks for the info.
I cant see the pics on my owrk pc so cant see what needs to be done to get them to fit.
Is it possible to still buy the 9006J bulbs?
Cheers for your help. :D
