Arrived; the volk wheel that weight 7.44kg
Mike B
  • Replies 67
actually looking at your pic the front tyre looks stretched... so yeah...
I did ask if they do a low and high dish, but was told they don't so that's that explanation out as well!
oh well, there goes my theory..! I'll have to wait to plant that sucker on to see if it fits...
Wouldn't CW need the new wheels now to do full Geometry set up ?
They are almost identical to the wheels currently on aside weight, so he says no...., besides he'd have to be damn good as I only have one atm!
He just called; car is ready, but one section of the train journey has been cancelled, replaced by bus, so it's a 6 hour journey to get to him :rolleyes:
very nice wheel, what finish is this?....
http://img512.imageshack.us/img512/5398/as6dm0.jpg
MVP has these at £1400 approx
http://www.mvpmotorsports.com/Templates/frmTemplateM7.asp?SubFolderID=2107&SearchYN=N
only thing, they look very delicate and flimsy to use in anger over some of our roads....??
that looks awesome....wonder about the strength of these llightweight wheels now that you mention it.
Out with the gym, workout in the garage instead.
They don't fit... on two counts.. I need 5mm extra clearance which i have a plan to get, but more worryingly the centre hole is miles off...
everyone else who uses volk.. do you have to use a spigot ring....?
I hope not with custom wheels this expensive!
Correct in this field means the hole is at least as big, probably bigger then the nose of the hub, IE, they'll go on ;) Unless you get to talk to the engineers at wheel places you are whatsitting in the wind. That's why I like Image Wheels for road car applications, you can actually speak to the guy on the lathe. Same with Barnby Engineering wheels (No use for Supras, he does nothing bigger than 13 inch rims, but the ones he does do are a dream).
http://www.mb-racingwheels.com/index.htm
http://www.imagewheels.co.uk/
As Chris says most aftermarket wheels will have an oversize centre hole, basically so they can fit a whole range of different car models.
