supra matt Posted January 12, 2008 Share Posted January 12, 2008 yes there both 9.5 front and back i run 265 , 35 on the back and 245 , 40 on the front, . Link to comment Share on other sites More sharing options...
Mike B Posted January 12, 2008 Author Share Posted January 12, 2008 actually looking at your pic the front tyre looks stretched... so yeah... I did ask if they do a low and high dish, but was told they don't so that's that explanation out as well! oh well, there goes my theory..! I'll have to wait to plant that sucker on to see if it fits... Link to comment Share on other sites More sharing options...
AshBhp Posted January 12, 2008 Share Posted January 12, 2008 Wouldn't CW need the new wheels now to do full Geometry set up ? . Link to comment Share on other sites More sharing options...
Mike B Posted January 12, 2008 Author Share Posted January 12, 2008 Wouldn't CW need the new wheels now to do full Geometry set up ? They are almost identical to the wheels currently on aside weight, so he says no...., besides he'd have to be damn good as I only have one atm! He just called; car is ready, but one section of the train journey has been cancelled, replaced by bus, so it's a 6 hour journey to get to him Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 12, 2008 Share Posted January 12, 2008 No, geo is wheel independent in this case. I have sent you an e-mail Mike. I also fond why the car was pulling under the brakes Link to comment Share on other sites More sharing options...
Pete Posted January 13, 2008 Share Posted January 13, 2008 I found these at the Autosport International show today. They are indeed very easy to lift. They had some other rather spiffing magnesium ones too. Link to comment Share on other sites More sharing options...
imi Posted January 13, 2008 Share Posted January 13, 2008 very nice wheel, what finish is this?.... http://img512.imageshack.us/img512/5398/as6dm0.jpg MVP has these at £1400 approx http://www.mvpmotorsports.com/Templates/frmTemplateM7.asp?SubFolderID=2107&SearchYN=N only thing, they look very delicate and flimsy to use in anger over some of our roads....?? that looks awesome....wonder about the strength of these llightweight wheels now that you mention it. Link to comment Share on other sites More sharing options...
Gaz Walker Posted January 14, 2008 Share Posted January 14, 2008 Glad it arrived safe and well Mike. So I take it it fitted?! Link to comment Share on other sites More sharing options...
Mike B Posted January 14, 2008 Author Share Posted January 14, 2008 That's on tonights to do list... but I have an appointment in the gym, so it might have to wait until tomorrow.... oooh the suspense! Link to comment Share on other sites More sharing options...
Mike B Posted January 14, 2008 Author Share Posted January 14, 2008 Out with the gym, workout in the garage instead. They don't fit... on two counts.. I need 5mm extra clearance which i have a plan to get, but more worryingly the centre hole is miles off... everyone else who uses volk.. do you have to use a spigot ring....? I hope not with custom wheels this expensive! Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 14, 2008 Share Posted January 14, 2008 Get some alloy or stainless rings turned up, plastic isn't really good enough. This is typical of 95% of aftermarket rims, short of having a true custom rim made, say by the likes of BBS, Image Wheels, Jongbloed, et cetera. Link to comment Share on other sites More sharing options...
merckx Posted January 14, 2008 Share Posted January 14, 2008 the centre hole is miles off... everyone else who uses volk.. do you have to use a spigot ring....? Yes, hub bore dia 73mm Link to comment Share on other sites More sharing options...
Pete Posted January 14, 2008 Share Posted January 14, 2008 My Volk Challenge wheels have alloy rings. That's a big disappointment considering you were informed they'd be the correct centre diameter size. Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 14, 2008 Share Posted January 14, 2008 Correct in this field means the hole is at least as big, probably bigger then the nose of the hub, IE, they'll go on Unless you get to talk to the engineers at wheel places you are whatsitting in the wind. That's why I like Image Wheels for road car applications, you can actually speak to the guy on the lathe. Same with Barnby Engineering wheels (No use for Supras, he does nothing bigger than 13 inch rims, but the ones he does do are a dream). http://www.mb-racingwheels.com/index.htm http://www.imagewheels.co.uk/ Link to comment Share on other sites More sharing options...
Pete Posted January 14, 2008 Share Posted January 14, 2008 Strange fact of the day....At the moment I have the daughter of the bloke that setup Image wheels working for us. Well..he was the director. Mike Fones. Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 14, 2008 Share Posted January 14, 2008 So can we expect a rim change on your car soon? Link to comment Share on other sites More sharing options...
Pete Posted January 14, 2008 Share Posted January 14, 2008 So can we expect a rim change on your car soon? I doubt it. Maybe I'll have to chat her up a bit and see how much influence he still has. Link to comment Share on other sites More sharing options...
Nic Posted January 15, 2008 Share Posted January 15, 2008 They don't fit... on two counts.. I need 5mm extra clearance which i have a plan to get, but more worryingly the centre hole is miles off... As Chris says most aftermarket wheels will have an oversize centre hole, basically so they can fit a whole range of different car models. Link to comment Share on other sites More sharing options...
