AEM EMS for Jap Spec JZA80?
ttsupra97
Hi guys,
Just wondering if anyone knows for sure whether this is available? I heard some talk of it before, but nothing concrete. I've posted this Q on AEM's forum, but thought I'd check here as well.
If not, I still might try to adapt the US model using my Fields harness to move the appropriate wires around. Surely there couldn't be too many changes necessary. After all, the Jap spec doesn't have things like EGR for example.
Anyone have a ECU pinout diagram from the Jap spec model? I had a look at mkiv.co.nz's ECU pinout diagram, but since that lists the air-flow meter pin I figure that's a US spec diagram (correct me if I'm wrong though).
As for the base maps that come with the AEM, I currently have the US 550cc injectors, inlet cam, and turbo's in my Jap spec now, so I figure it will be enough to get me up and running to the tuning shop.
Cheers,
Tony.
Tony,
When I spoke to AEM a month or so ago they said they now supported the J-Spec. If you are in the UK and wish to purchase one you need to speak to GEMS http://www.gems.co.uk
As for the pinout, I believe they are the same just depends on what is wired up, if you specify that it is a J-Spec you will get the correct maps etc.
Hope this helps.
Wes
