liam1 Posted January 9, 2008 Share Posted January 9, 2008 going to replace my veilside front on my n/ to a stock one with active spoiler is it a easy job swapping them over. Link to comment Share on other sites More sharing options...
merckx Posted January 9, 2008 Share Posted January 9, 2008 That will obviously depend on if you want the active spoiler to work. Link to comment Share on other sites More sharing options...
liam1 Posted January 9, 2008 Author Share Posted January 9, 2008 not fussed if its permantely in the active position that would be fine, how about fittings the stock spoiler has no bolts will i need to replace those or will the ones holding my veilside be any good. Link to comment Share on other sites More sharing options...
Daston Posted January 9, 2008 Share Posted January 9, 2008 your veilside one should have the fittings in the same place as the stock one (well both my TS and border ones do so guess veilside will be the same) so you should be able to use your current nuts and bolts Link to comment Share on other sites More sharing options...
tomgeer Posted January 9, 2008 Share Posted January 9, 2008 Don't know about the difficulty of changing the bumper, but I will commend you for going back to stock Link to comment Share on other sites More sharing options...
jevansio Posted January 9, 2008 Share Posted January 9, 2008 Liam, I have the lip bolted onto the oem so it's always in the down position, you need none of the gubbins (just the rubber lip) so there's no additional weight. I had a go at retro fitting the full lot origionally and got bored as it wasn't a simple bolt on affair. Link to comment Share on other sites More sharing options...
JamesC Posted January 9, 2008 Share Posted January 9, 2008 Do you not find it too low when it's always in the down position? Link to comment Share on other sites More sharing options...
