styggen82 Posted January 11, 2008 Share Posted January 11, 2008 http://www.max-boost.co.uk/max-boost/supra/turbo.htm here`s the system, as you can see there`s alot that can interfere with the boost.... Link to comment Share on other sites More sharing options...
dini_the_owl Posted January 12, 2008 Share Posted January 12, 2008 what nur spec have you got? Link to comment Share on other sites More sharing options...
supraguye Posted January 12, 2008 Author Share Posted January 12, 2008 http://www.max-boost.co.uk/max-boost/supra/turbo.htm here`s the system, as you can see there`s alot that can interfere with the boost.... Hey Mate .... I can't thank you enough for all the help given so far ... this diagram is really helpful Link to comment Share on other sites More sharing options...
supraguye Posted January 12, 2008 Author Share Posted January 12, 2008 what nur spec have you got? Nur-Spec S Link to comment Share on other sites More sharing options...
supraguye Posted January 15, 2008 Author Share Posted January 15, 2008 Took my car out to another Mate before pulling out the turbos. He drove the car (a lil too fast for my liking) and told me that both turbos are quite fine. From his analysis, my problem could be one of 2 things, a solenoid, or an actuator. I have a greddy Profec B in waiting, he's suggesting that I install it first as it gets rid of the stock solenoids. If this fails, the next step would be to change the actuators Any thoughts on this would be appreciated. Thanks Link to comment Share on other sites More sharing options...
bodilx6 Posted January 15, 2008 Share Posted January 15, 2008 If you are going to check teh VSV's and actuators, take a look here: http://www.97supraturbo.com/FAQ.html A looot of info on troubleshooting Link to comment Share on other sites More sharing options...
supraguye Posted January 15, 2008 Author Share Posted January 15, 2008 thanks mate Link to comment Share on other sites More sharing options...
supraguye Posted January 15, 2008 Author Share Posted January 15, 2008 If you are going to check teh VSV's and actuators, take a look here: http://www.97supraturbo.com/FAQ.html A looot of info on troubleshooting Also found this thread from Ian C: http://www.mkivsupra.net/vbb/showthread.php?t=35926 Link to comment Share on other sites More sharing options...
supraguye Posted April 1, 2008 Author Share Posted April 1, 2008 finally got around to pulling out the twins. The front turbo was in perfect condition, but found that the compressor wheel of the back turbo was damaged and there was ALOT of shaft play. Swaped it out for a used turbo which seems to be in good workign condition. Gave the car its first run and found that I only hit 1 bar at most with no Restrictor Ring fitted. Question I have here is, should I still fit a restrictor ring even if the car is not doing as much boost as it should do? THanks Link to comment Share on other sites More sharing options...
