Rear light white lenses advice needed
supradibbs
Got a donar set now so will be changing the yellow indicator for a nice white one any advice on stripping down the light and fitting in the new lense will be gratefully recieved (come on lovatt you must know :D )
Also what bulbs will i then need
Thaks guys and gals :nana:
It's literally the same principle as doing the front headlights, you will need to remove the small screws and stick the light in the oven, prise it apart, remove the chrome housing and remove the orange lense.
Then you will need to dremel, cut or file down the tabs on the clear lense in order to make it fit. ( It will be aparent once you have stripped it down).
Sorry I can't remember to much detail as it was years ago when I done this mod.
Guest Cosmic Chaos
bulbs needed: wedge 7440 (there are some on ebay really nice, look in the for sale section) if you've the 98 tails, or 1156 if you've the 93.96 ones. in this case you can buy philips silver vision P21W.
