window trim removel
8800
hi, i am trying to remove the window trim and refit it. theres a big gap starting half of the trim until the rear quarter window. I have took off the screws behind the rubber, but i still cant move the trim,
do i have to remove the rear quarter window as well? or is there other screws hidden somewhere? any help would be much appreciated :)
http://img247.imageshack.us/img247/9065/dsc00135ri8.th.jpg
http://img247.imageshack.us/img247/5098/dsc00133jm3.th.jpg
thanks for the reply Nic, do you happen to know where the clips located?
I can't remember but they hold the trim piece onto the body, I *think* if you look above the trim you can see them. It's a long time since I replaced mine so my memory is a bit sketchy I'm afraid.
