supraguye Posted January 8, 2008 Share Posted January 8, 2008 I've had 18" deep dish alloys fitted for the last 2 months or so. Clean these regularly, and have been noticing and increased number of scratches on the lip from wiping with my chamois. If ther anyway to get rid of these, or if not at least prevent further scratching. THanks Link to comment Share on other sites More sharing options...
Suprash Posted January 8, 2008 Share Posted January 8, 2008 Im having trouble just keeping my polished lips, polished......there must be some sort of sealent you can use......? Link to comment Share on other sites More sharing options...
Gaz6002 Posted January 8, 2008 Share Posted January 8, 2008 Just wash with warm soapy water and a sponge or soft cloth. Mine have lasted 13 months pretty much perfectly... Link to comment Share on other sites More sharing options...
Jspec Germany Posted January 8, 2008 Share Posted January 8, 2008 Mothers. Link to comment Share on other sites More sharing options...
colsoop Posted January 8, 2008 Share Posted January 8, 2008 Soap and water to clean the dirt and grime follwoed by brilliant metal polish or mothers to clean them. To protect them klasse sealant glaze (or similar sealant glaze) followed by a carnauba wax. Repeat regulalrly. Only use soft quality microfibre cloths no old t shirts ! or cloths Link to comment Share on other sites More sharing options...
supra_aero Posted January 8, 2008 Share Posted January 8, 2008 I had a polished lip on my rx7 wheels and they never got scractched. I used nano cleaner (green and black bottle), with nano wheel wax on top to stop dust gathering on it. Literally all you'd need after using that stuff regularly was a splash of water and the dirt comes off. I can't remember the exact brand but you can get it in halfords. I'll check next time I wash my car (don't have polished lip wheels anymore so not used it for sometime). Link to comment Share on other sites More sharing options...
supra_aero Posted January 8, 2008 Share Posted January 8, 2008 Soap and water to clean the dirt and grime follwoed by brilliant metal polish or mothers to clean them. To protect them klasse sealant glaze (or similar sealant glaze) followed by a carnauba wax. Repeat regulalrly. Only use soft quality microfibre cloths no old t shirts ! or cloths And yes only use quality microfibres as above and do it regularly. That said, I use old soft toothbrushes to clean the spokes. Does a remarkable job but don't use that on the polished lip!! Link to comment Share on other sites More sharing options...
supraguye Posted January 8, 2008 Author Share Posted January 8, 2008 Thanks for all the responses Guys. Check this out: http://www.autogeek.net/mopomikit.html Link to comment Share on other sites More sharing options...
Suprash Posted January 8, 2008 Share Posted January 8, 2008 Soap and water to clean the dirt and grime follwoed by brilliant metal polish or mothers to clean them. To protect them klasse sealant glaze (or similar sealant glaze) followed by a carnauba wax. Repeat regulalrly. Only use soft quality microfibre cloths no old t shirts ! or cloths Man I love old t-shirts, the whole family saves them for rags for me.... My polished lips on the rear are a mess mate, they got washed regular at least every 4 or so days, tops one week once..........but the build and staining on them is unreal, chrome is a lot tougher then polished, so who ever told me otherwise is clearly lying.........in fairness though it has been about 2 weeks or so since I last cut them back, but been so busy lately..... Where do I get this klasse sealent glaze......? Link to comment Share on other sites More sharing options...
Stevo Posted January 8, 2008 Share Posted January 8, 2008 Sorry for the length of it but thought this info would help: Wheel Surface Cleaning: It is important to keep wheel surfaces clean, as well as improving the overall look of the vehicle leaving them dirty can have many adverse effects; the black powder coating on the surface of your wheel has four components; a static friction charge (caused by the pads contact with the rotors) that attracts dirt, road tar and other contaminants kicked up by both your vehicle and others. Friction heats the pads and callipers to extremely high temperatures, and causes tiny particles of hot metal to wear off and sent flying in different directions. Many of these hot metal particles land on your rim and literally fuse themselves to the surface. Finally there is brake pad adhesive, modern brake pads are complex compounds of metals, synthetic materials and adhesives (the binder system) which is designed to wear away under friction like the rest of the pad. The adhesives used in brake pads can be very difficult to remove and they are also corrosive and will etch the wheel surface, the metal particles from the pads and rotors will become a conduit for rust compromising the paint surface of your wheel Wheel cleaning is not that difficult, especially if you use the correct tools, they have to work safely but effectively. Wheel cleaners that contain acid are the most dangerous, there are wheel acids that are safe if used with care and the directions are followed precisely. Accidents and expensive wheel replacements can always be avoided if you do some research and are smart about your choices. Always check the products MSDS and its pH value before you use it. It is always preferable that you use a 100% acid-free product with a pH of 7.5 – 8.0 Cleaning Clear Coated Wheels: •Ensure wheels and rotors are cool before applying cold water as this may cause them to warp. Hose off as much initial grime as you can. Rinse up into the wheel well to wash away road kill, mud and other debris. •Use detailing clay to remove any imbedded contaminants •Use a solvent based cleaner to remove any road tar •Apply a solution of P21S Total Auto Wash to wheel-wells and tyres, and let soak in, agitate with a long-handled boars haired brush before rinsing •Spray P21S Wheel Cleaner (Gel or Liquid) this cleaner is 100% acid-free and will not damage any type of wheel finish. (Gel for badly soiled and regular for normal soil) onto wheel rims and lat soak in (for badly soiled surfaces us P21S-Red (422) •Before finally removing cleaner, agitate with a soft brush and then rinse off (See Wheel Brushes) •Rinse wheel surface thoroughly with clean water (to avoid splashing paint surface rise by pouring a bucket of water over each wheel from the top down •Remove any surface imperfections with a suitable clear coat polish (dependant upon extent of damage) •Dry wheels with a towel, apply a polymer sealant (ZoopSeal) to the surface of the wheels, it will protect the finish from brake dust and the elements and also make them easier to keep clean. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 8, 2008 Share Posted January 8, 2008 What has not been mentioned is it very much depends on whether your polished wheel lips are polished and then lacquered or just polished and not coated, if lacquered then treat them like you would paintwork after proper cleaning, if polished then use a proprietary metal polish Solvol etc, and i have found the Auto Glim have a very good spray on wheel protector/polish that just needs to be buffed off, and it protects very well. Link to comment Share on other sites More sharing options...
