Surely an engine out job
bignum
Started taking my turbos off tonight, got stuck on the 4 nuts to take turbos off the manifold you just cant get at them, considering pulling the engine out as ive pulled all my hair out allready, well soaked everthing with pentrate lube and have another go tomorrow when i can stand up straight, moan over,:)
Are you stuck on the 3 that need to be reached from underneath? Two of them are tricky, but there's one thats an absolute nightmare. I ended up using heat and a 4 foot extension bar with a one of the 'wobbly' joints (can't remember what they're called :D ). Bent two of the extension bars in the process too!
The heat does help, but they need to be red hot for it to make a real difference
When i was going single and removing my stock turbos, it must have been the worst turbo job i ever did and would not go through it again.
Expect plenty skinned knuckles etc.
my techinique was to keep removing parts until the ba$tards came off.
They are a right bastard to get off, patience and elbow grease do it though mate.:)
