Scoboblio Posted January 9, 2005 Share Posted January 9, 2005 Being a tight bugger I'm not going to get a turbo timer until I go BPU. How long do you think it's necessary to leave the engine running after say a 20-30min run with a fair bit of second turbo action? I've just been leaving it running for say 3-4 mins after each run. Does this sound about right or am I in danger of causing damage? Cheers. Link to comment Share on other sites More sharing options...
Sharpie Posted January 9, 2005 Share Posted January 9, 2005 I'd say that was plenty of time. I have a TT but, still do a local loop of ~2-3miles (off boost) on the way home after some action to cool off and the TT is at 0 by then. I find that WITH a TT you save on the time sat in the car as it works it out for you and is normally less time than what you think. There is some info in the manual about speed x = cool down time Y but, I forget what it is off the top of my head. Link to comment Share on other sites More sharing options...
Tom Posted January 9, 2005 Share Posted January 9, 2005 I do 3-4 mins everytime, can't go wrong then! Link to comment Share on other sites More sharing options...
Toms Supra Posted January 9, 2005 Share Posted January 9, 2005 My timer is set to 1 minute is that not long enough? Link to comment Share on other sites More sharing options...
Getrag Posted January 9, 2005 Share Posted January 9, 2005 My timer is set to 1 minute is that not long enough? Same...... Mind you, i dont know what TT I have yet, or what all the functions are. Link to comment Share on other sites More sharing options...
Sharpie Posted January 9, 2005 Share Posted January 9, 2005 OK, here is what Mr T recommends in the manual: ********************** After high speed or extended driving etc.. requiring a heavy engine load, the engine should be allowed to idle as showin in the chart below before turning it off: High speed driving: 50 mph - idling time about 20 seconds 63 mph - idling time about 1minute Continued driving above 63 mph - idling time about 2 mins. ************************ If you have a TT then set it to Auto and it will work it out for you OR after a good session give yourself a couple of miles cool down and you'll be fine. IF you can't give yourself a couple of miles cool down then, I'd use 2mins (min)at idle with maybe the bonnet open too. All IMO Link to comment Share on other sites More sharing options...
Ian C Posted January 9, 2005 Share Posted January 9, 2005 High speed driving: 50 mph Hahahahahahahahahahahaaaaaaaaaaaaaaaaa did they miss a 1 off the front? -Ian Link to comment Share on other sites More sharing options...
Scoboblio Posted January 9, 2005 Author Share Posted January 9, 2005 Continued driving above 63 mph - idling time about 2 mins. So that would mean the average person on this BBS should be idling for about.... 5 mins? Link to comment Share on other sites More sharing options...
mikeb Posted January 10, 2005 Share Posted January 10, 2005 Remember that leaving the car idling at the end of a journey (especially a thrash), leads to heat soak throughout the engine bay - the turbo's might be cooling down, but the rest of the engine will be getting hotter. The best solution is to drive your last 1/2 mile or so without using any boost. I know that's a challenge for most of you lot though... Link to comment Share on other sites More sharing options...
Tom Posted January 10, 2005 Share Posted January 10, 2005 Maybe I'll idle for less then as I usually stay off boost for about 10 mins on the way back from somewhere then leave it to idle for a a few mins. Link to comment Share on other sites More sharing options...
Ian R Posted January 10, 2005 Share Posted January 10, 2005 I have a HKS Turbo timer that calculates the idle time automatically on a motroway run is up to 5 mins but after a couple of mins town driving only about 11 secs Link to comment Share on other sites More sharing options...
