cheekymonkey Posted January 6, 2008 Share Posted January 6, 2008 Had a great day today at SRR, thanks to Charlie and Ryan.G Ryan fitted my new Apexi PowerFC ECU and we got onto the rolling road. Did several runs while Ryan worked his magic. Decided to go TTC to see what difference it makes to the power curve and we got Charlie to do a printout of both at the same time (see attached). I really do like the way the car drives now, as you can see the power delivery is much smoother, and more like what it will be like once I eventually do go single. The green lines are Seq and the red line is TTC where I get my max power. This is all running at 1.0 bar with the stock j-spec twins.... so bring on 1st decat pipe EDIT: Please bear in mind, as Ryan mentiones later on in the thread that is NOT comparing Seq vs TTC on a stock ECU *grin* Link to comment Share on other sites More sharing options...
tomgeer Posted January 6, 2008 Share Posted January 6, 2008 Thats good going Link to comment Share on other sites More sharing options...
tucky40 Posted January 6, 2008 Share Posted January 6, 2008 Excellent stuff cheekymonkey!! Great to see the comparison on paper for the first time. Link to comment Share on other sites More sharing options...
jevansio Posted January 6, 2008 Share Posted January 6, 2008 Good stuff, I never tried TTC on mine, Is there any reason why the TTC makes more power than sequential once both turbos are fully spooled??? Link to comment Share on other sites More sharing options...
Antnicuk Posted January 6, 2008 Share Posted January 6, 2008 impressive stuff, what does TTC stand for?, I assume that it means non sequential Link to comment Share on other sites More sharing options...
tucky40 Posted January 6, 2008 Share Posted January 6, 2008 looking at that graph sequential only has the advantage till 3500rpm, from 4000rpm the TTC is producing 80bhp more!! thats pretty damn good and sounds like it would have the advantage on the road any day. Might have to see if Ian would be happy to map my emu in ttc after all!! Link to comment Share on other sites More sharing options...
cheekymonkey Posted January 6, 2008 Author Share Posted January 6, 2008 impressive stuff, what does TTC stand for?, I assume that it means non sequential TTC - True Twin Conversion http://www.internetwork.org.uk/ttc/ttc.htm Link to comment Share on other sites More sharing options...
DamanC Posted January 6, 2008 Share Posted January 6, 2008 Now that is a 'curve' Link to comment Share on other sites More sharing options...
cheekymonkey Posted January 6, 2008 Author Share Posted January 6, 2008 Now that is a 'curve' I can tell you, not only does it look smooth but it drives smooth too. It does seem easier to pull away and it's just like driving a NA until you *really* want to boot it. Also - the car sounds more aggressive at lower revs, I really have no idea why that is but I like it! Link to comment Share on other sites More sharing options...
SimonB Posted January 6, 2008 Share Posted January 6, 2008 Good stuff, I never tried TTC on mine, Is there any reason why the TTC makes more power than sequential once both turbos are fully spooled??? The boost will be spiking higher. So they're not the same, the TTC will be running more boost. If they were running the same level of boost the sequential setup would produce the same power and be much better low down too. That's why Toyota used it! Link to comment Share on other sites More sharing options...
Ryan.G Posted January 6, 2008 Share Posted January 6, 2008 Please note that just running a Stock Ecu in TTC mode will not produce similar results. Alot of ignition timing work is needed to produce a similar setup. Ryan P.s Loved the Car! Link to comment Share on other sites More sharing options...
SimonB Posted January 6, 2008 Share Posted January 6, 2008 Please note that just running a Stock Ecu in TTC mode will not produce similar results. Alot of ignition timing work is needed to produce a similar setup. Ryan P.s Loved the Car! Ah, didn't notice it was a full remap, that makes more sense. Link to comment Share on other sites More sharing options...
cheekymonkey Posted January 6, 2008 Author Share Posted January 6, 2008 I was about to say, Ryan will be along shortly to comment! Thanks for you work today mate, proper job. Will be back when I am fully de-catted and we can really let the beast roar Link to comment Share on other sites More sharing options...
adam bell Posted January 6, 2008 Share Posted January 6, 2008 i prefer ttc mode especialy this time of year when its wet out as you dont use any turbo power,making it easy to drive Link to comment Share on other sites More sharing options...
Ryan.G Posted January 6, 2008 Share Posted January 6, 2008 The boost will be spiking higher. So they're not the same, the TTC will be running more boost. If they were running the same level of boost the sequential setup would produce the same power and be much better low down too. That's why Toyota used it! Same Boost levels Only difference is i was able to get more ignition timing in on the TTC setup at the top end. Ryan Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 6, 2008 Share Posted January 6, 2008 Another convert:) i have run mine in TTC virtually since i got it, much prefer the power delivery. Link to comment Share on other sites More sharing options...
Ryan.G Posted January 6, 2008 Share Posted January 6, 2008 Another convert:) i have run mine in TTC virtually since i got it, much prefer the power delivery. Have you done any work with the Seq Setup Dick back to back with the TTC setup as i was quite surprised how much more timing i could get in with the setup. Although the boost levels were the same it also flowed alot more air too in TTC as the injector duty was higher and reached my max safe duty level at 1bar (87%) Ryan Link to comment Share on other sites More sharing options...
R Black Posted January 6, 2008 Share Posted January 6, 2008 I like this thread, i not heard much good about ttc til now, & my interest is peaked, how much for a Apexi PowerFC ECU then? Link to comment Share on other sites More sharing options...
cheekymonkey Posted January 6, 2008 Author Share Posted January 6, 2008 Mine was 650 I think, well it was 950 with the mapping! So lots of money (if you can find one) but I plan to keep mine until I eventually go Single anyway, so it's not money down the crapper. I do plan however to get the most out of my stock tubbies, as much as I can! Link to comment Share on other sites More sharing options...
R Black Posted January 6, 2008 Share Posted January 6, 2008 So whats your best guesstimate BHP/Torque of full bpu ecu mapped ttc mode? Link to comment Share on other sites More sharing options...
cheekymonkey Posted January 6, 2008 Author Share Posted January 6, 2008 Turn your speakers on http://s178.photobucket.com/albums/w279/cheekysupra/?action=view¤t=run.flv Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 6, 2008 Share Posted January 6, 2008 Have you done any work with the Seq Setup Dick back to back with the TTC setup as i was quite surprised how much more timing i could get in with the setup. Although the boost levels were the same it also flowed alot more air too in TTC as the injector duty was higher and reached my max safe duty level at 1bar (87%) Ryan No back to back, i just changed it to diagnose a problem and just liked it, where abouts in the RPM and boost range are you finding that you can add more timing advance? is it above 5,500RPM ? PM me if you don't want to discuss here, if you remember my odd det on the RR, funnily en ought i have not seen any recurrence of that, despite adding more timing advance, than it was supposedly running that day, plus I'm running leaner, don't know what was going on then:blink: but i was also making 390ftlb at just short of 5,000 RPM that day, despite the low BHP figure. Link to comment Share on other sites More sharing options...
Wez Posted January 6, 2008 Share Posted January 6, 2008 Nice info guys, that TTC curve is much better than I expected. I was down at SRR shortly after although I went to four Shells and couldnt get V-Power Link to comment Share on other sites More sharing options...
miko_supra Posted January 6, 2008 Share Posted January 6, 2008 very smooth graph there. think i might give this a go myself when im next off work Link to comment Share on other sites More sharing options...
Wez Posted January 6, 2008 Share Posted January 6, 2008 very smooth graph there. think i might give this a go myself when im next off work It wont look anything like that on a stock ECU. Link to comment Share on other sites More sharing options...
